[Qgis-developer] Some errata on linux installations of qgis
Martin Dobias
wonder.sk at gmail.com
Sat Nov 10 08:34:42 EST 2007
On Nov 8, 2007 9:15 PM, <mccue at acm.caltech.edu> wrote:
> /home/mccue/dev/cpp/share/qgis/python/plugins/new_layer/__init__.py
> when I use it for qgis built from source. This plugin seems to work,
> except in case (III), I get error messages in a separate window
> (labelled "Error"), of the form:
> Couldn't load plugin "newlayer"
> Traceback (most recent call last):
> File "", line 2, in
> ImportError: No module named newlayer
> The plugin manager now reports this plugin as __error__
> __error__ appears in the name field on the plugin manager (also in
> the version and description fields)
Isn't the problem that you don't have 'psycopg' python module on your
system? I've tried it now on my box an run into similar problems.
> This worked (I had to do some tweaking--I think libgdal1-1.3.2 was
> what was available so I used it). I don't know whether these commands
> are available on your website (your wiki for installation didn't have
> it--I can't check now because the wiki is down).
that's known problem, gdal-config tool in ubuntu feisty package
returns wrong library path to GDAL, seems to be OK in Gutsy.
> cmake/Python.cmake needs to be modified:
> Change
> #TRY_RUN_PYTHON (RES
> # "import PyQt4.pyqtconfig\nprint PyQt4.pyqtconfig._pkg_config['pyqt_sip_dir']"
> # PYQT_SIP_DIR)
> to
> TRY_RUN_PYTHON (RES
> "import PyQt4.pyqtconfig_nd\nprint PyQt4.pyqtconfig_nd._pkg_config['pyqt_sip_dir
> PYQT_SIP_DIR)
> since
> doesn't work (PyQt4.pyqtconfig doesn't have _pkg_config) and
> PyQt4.pyqtconfig_nd._pkg_config['pyqt_sip_dir']
> does (PyQt4.pyqtconfig_nd has _pkg_conifg)
Eh, I have never seen or heard of pyqtconfig_nd - what's that? where is it from?
> With this change make goes all the way through. Now, on make install
> BINDINGS_GLOBAL_INSTALL
> had to be set to make the installation work
Why? it must compile also without it being set.
> Then make install died with this error
> CMake Error: Error in cmake code at
> /home/mccue/dev/cpp/qgis/cmake_install.cmake:50:
> FILE Internal CMake error when trying to open file:
> /home/mccue/dev/cpp/qgis/install_manifest.txt for writing.
> Current CMake stack: /home/mccue/dev/cpp/qgis/cmake_install.cmake
> make: *** [install] Error 255
I think that's because of some permissions problems. Probably you've
run 'sudo make' and that generated that install_manifest.txt file with
root permissions so now it can't be changed with usual user.
Regards
Martin
