[Qgis-developer] Minimal requirements
Aaron Racicot aaronr at z-pulley.com
Sun Nov 11 00:33:04 EST 2007
Martin,
Just wanted to point out that there is a dependency amongst dependencies in
that list between QT and PyQT:
- For QT4.3.X you need a PyQt that is compatible... i.e. PyQt4.2.x will not
work.
Also, Riverbank states that "Note that we only test against the latest
stable version of Python and the latest stable version of Qt."  They also
ship their binary installer of PyQt for Win requiring Python2.5.
Just some observations...
A
 Aaron Racicot - GIS Programmer
 360.221.2441 - aaronr at z-pulley.com
 z - p u l l e y
 pobox 1614
 langley wa 98260
 www.reprojected.com
-----Original Message-----
[mailto:qgis-developer-bounces at lists.qgis.org] On Behalf Of Martin Dobias
Sent: Saturday, November 10, 2007 4:06 AM
To: Mateusz Loskot
Cc: qgis-developer at lists.qgis.org
Subject: Re: [Qgis-developer] Minimal requirements
I'll try to summarize it here (for QGIS 0.9):
Required build deps:
- CMake >= 2.4.3
- Flex, Bison
Required runtime deps:
- Qt >= 4.2.0
- Proj >= ? (known to work with 4.4.x)
- GEOS >= 2.2 (3.0 is supported, maybe 2.1.x works too)
- Sqlite3 >= ? (probably 3.0.0)
- GDAL/OGR >= ? (1.2.x should work)
Optional dependencies:
- for GRASS plugin - GRASS >= 6.0.0
- for georeferencer - GSL >= ? (works with 1.8)
- for postgis support and SPIT plugin - PostgreSQL >= ?
- for gps plugin - expat >= ? (1.95 is OK)
- for mapserver export and PyQGIS - Python >= ? (probably 2.3)
- for PyQGIS - SIP >= 4.5, PyQt >= 4.1
Recommended runtime deps:
- for gps plugin - gpsbabel
I hope I haven't missed anything. Basically no cutting edge releases
of deps are needed.
Martin
On Nov 10, 2007 11:37 AM, Mateusz Loskot <mateusz at loskot.net> wrote:
> Hi,
> Where can I find information about minimal set of required software
> packages for QGIS?
> I know QGIS uses GDAL, PostGIS, Expat, etc. but are all these packages
> required or just recommended if one needs ie. PostGIS support.
> But what are minimal requirements?
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
