[Qgis-developer] small note about PyQt
Tim Sutton
tim at linfiniti.com
Sun Nov 11 08:49:02 EST 2007
Hi
Right. It was based on Aarons previous reports of incompatibility
between Qt4.3.2 and PyQt4.3.1 that I said this. If I understood Jef
propertly, Qt 4.3.2 seemed to work fine with PyQT4.3.1 under
MSVC.....what can I say - its all a bit confusing :-)
Regards
Tim
2007/11/11, Aaron Racicot <aaronr at z-pulley.com>:
> Martin,
> Just a few notes from personal experience... not sure if they are just
> related to the tests I did or indicative of inherent incompatibilities but:
> 1) I have tested QT4.3.2 with PyQt4.3.1 and SIP 4.7 on both Win and Linux,
> all built from source and had issues. For me I have never been able to get
> a QT4.3.2 build to work with PyQt4.3.1. Again, maybe that is just me, but I
> have tried and failed.
> 2) The Win installer of PyQt from Riverbank (by far the easiest way to
> install for most) is built with the Microsoft compilers and is not
> compatible with the MingW built versions of QT or QGIS in general. That is
> why Tisham includes the pyqt4 with the win installer now (a MingW version of
> pyqt4). If you have the Riverbank version already installed it will not
> work without writing over the PyQt4 stuff in site-packages with the MingW
> version.
> I have not tried any of this in about a month because it is quite a time
> sink to try and deal with all of these installs and testing. Right now the
> only combo that I am happy with and know works on all architectures is
> QT4.3.1, PyQt4.3.1 and SIP4.7. That is what the release was built with and
> what I am using currently.
> I would love to hear others experience getting QT4.3.2 to work with the
> python bindings...
> A
> Aaron Racicot - GIS Programmer
> 360.221.2441 - aaronr at z-pulley.com
> z - p u l l e y
> pobox 1614
> langley wa 98260
> www.reprojected.com
> -----Original Message-----
> From: qgis-developer-bounces at lists.qgis.org
> [mailto:qgis-developer-bounces at lists.qgis.org] On Behalf Of Martin Dobias
> Sent: Saturday, November 10, 2007 3:40 AM
> To: QGIS-dev
> Subject: [Qgis-developer] small note about PyQt
> from IRC logs:
> 13:12:25 timlinux: FrankW: dont get qt 4.3.2 yet because last
> I
> checked qt 4.3.2 doesnt have pyqt support yet
> 13:12:38 : * FrankW sighs.
> 13:12:47 timlinux: so if you want to plunk with pygis stuff you
> should get 4.3.1
> 13:13:12 timlinux: lets check if the bindings have been updated
> for qt 4.3.2
> 13:13:24 PeteE: timlinux: I still think you need to be able to
> stretch the data befor appling the color ramp, cause Marco build the
> color ramp from the data type..
> 13:13:45 FrankW: Are you serious that pyqt works with 4.3.1
> but not
> 4.3.2? I'd be happy to get a basic qgis up and running and showing
> rasters.
> 13:14:13 timlinux: right then go ahead with 4.3.2 - python
> bindings
> will catch up
> 13:14:34 timlinux: python qt bindings are not a trolltech
> product
> but a third party
> This is not true. Bugfix releases of Qt - e.g. 4.3.1 and 4.3.2 are
> completely binary compatible between each other, so there's no need to
> for updated PyQt for them. Moreover, every 4.x version just adds new
> API and keeps binary compatibility. This means that if you should be
> able to shuffle versions of Qt and PyQt: if recent PyQt detects that
> you have older version of Qt it will just skip newer API when
> compiling bindings. Also, when you have older PyQt and newer version
> of Qt with some API additions, you can compile them as well...
> Martin
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
