[Qgis-developer] Possible fix for #804
Gavin Macaulay
gavin at macaulay.co.nz
Wed Nov 21 21:58:30 EST 2007
Steven,
I've been thinking about bringing up a dialog after the user has
selected a file to let them choose the file type (but only if they
haven't already done so in the file chooser).
Gavin
Steven Bell wrote:
> A question about a fix for ticket #804
> <https://svn.qgis.org/trac/ticket/804> - In the GPS plugin "Import other
> file" tool, the user must select a file and a file type, or else the
> file field will remain empty. It isn't immediately obvious to the user
> that selecting a file is not sufficient.
> My thought is to just display a warning dialog if the file type is
> empty. Currently, a warning is sent to the terminal, but the user
> doesn't see anything.
> Is there a different way that would be better than a dialog?
> Steven
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
