[Qgis-developer] [PATCH] extend data defined labels
Marco Hugentobler
marco.hugentobler at karto.baug.ethz.ch
Wed Oct 24 04:23:18 EDT 2007
Hi
Yes, it is applied now.
Btw, I noticed that in the labels dialog there is a transparency slider which
is disabled. Is it planned to support (global) transparency for labels soon?
If not, I think it is better to remove the slider and spin box from the
dialog. A user might think that transparency is supported and he just needs
to change some other settings.
Regards,
Marco
On Wednesday 24 October 2007 02:53:22 Tim Sutton wrote:
> Hi Marco
> Did you see this update?
> Regards
> Tim
> 2007/10/22, Jürgen E. Fischer <jef+qgis at norbit.de>:
> > Hi Marco,
> > On Tue, 31. Jul 2007 at 16:08:28 +0200, Marco Hugentobler wrote:
> > > Thank you for your contribution! The patch is fine and I will apply it
> > > to svn after 0.9 release (which is planned for 26. August).
> > I missed to save the sizetype field in the project. Attached an updated
> > patch.
> > Jürgen
> > Jürgen E. Fischer norBIT GmbH Tel.
> > +49-4931-918175-0 Dipl.-Inf. (FH) Rheinstraße 13
> > Fax. +49-4931-918175-50 Software Engineer D-26506 Norden
> > http://www.norbit.de
> > norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> > Rheinstrasse 13, 26506 Norden
> > GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
