[Qgis-developer] [QGIS Commit] SVN [godofredo] r7284 -
branches/ogr-plugin-branch/src/app
Martin Dobias
wonder.sk at gmail.com
Wed Oct 24 08:03:05 EDT 2007
Hi Godofredo,
when briefly looking at your changes I have some notes:
- it seems that QgsURIManager class does pretty much the same as
QgsDataSourceURI class which is already a part of core library
- you've introduced postresql dependency to core library - this is not
a good thing. One solution could be to make this dependency optional,
however I would prefer to move all postgres-related code to provider
or some other, more appropriate place.
Bye
Martin
On 10/23/07, godofredo contreras <frdcn at hotmail.com> wrote:
> Hi:
> This change was to add the ability to create mysql, oracle and postgres
> vector layers
> via ogr provider, the other changes were in the "add postgis layer dialog"
> that now
> support different kinds of connections in addition to postgres. The new
> classes in
> core/dbutilities are used to separate connection management from the dialogs
> and
> that will be used to update SPIT to work with mysql, and oracle.
> There are some plans to support layer creation, and Tim suggested to work a
> little
> with QgsVectorWriter to support some kind of export functionality, but I
> think this will
> be until second stage (once ogr spatial database layer creation and spit
> will be working ).
> Regars
> Godofredo Contreras
