[Qgis-developer] [QGIS Commit] SVN [godofredo] r7284 - branches/ogr-plugin-branch/src/app
godofredo contreras frdcn at hotmail.com
Wed Oct 24 14:11:31 EDT 2007
Hi Martin:
I checked QgsDataSourceUri and in fact it does almost the same
the QgsURIManager. To use it I need to add the type parameter
and add some methods. Do you think this could be possible?
QgsDataSourceUri is used only in postgres datasources?
Regards
Godofredo Contreras
> Date: Wed, 24 Oct 2007 14:03:05 +0200
> From: wonder.sk at gmail.com
> To: frdcn at hotmail.com
> Subject: Re: [Qgis-developer] [QGIS Commit] SVN [godofredo] r7284 - branches/ogr-plugin-branch/src/app
> CC: tutey at o2.pl; qgis-developer at lists.qgis.org
> Hi Godofredo,
> when briefly looking at your changes I have some notes:
> - it seems that QgsURIManager class does pretty much the same as
> QgsDataSourceURI class which is already a part of core library
> - you've introduced postresql dependency to core library - this is not
> a good thing. One solution could be to make this dependency optional,
> however I would prefer to move all postgres-related code to provider
> or some other, more appropriate place.
> Bye
> Martin
> On 10/23/07, godofredo contreras <frdcn at hotmail.com> wrote:
> > Hi:
> > This change was to add the ability to create mysql, oracle and postgres
> > vector layers
> > via ogr provider, the other changes were in the "add postgis layer dialog"
> > that now
> > support different kinds of connections in addition to postgres. The new
> > classes in
> > core/dbutilities are used to separate connection management from the dialogs
> > and
> > that will be used to update SPIT to work with  mysql, and oracle.
> > There are some plans to support layer creation, and Tim suggested to work a
> > little
> > with QgsVectorWriter to support some kind of export functionality, but I
> > think this will
> > be until second stage (once ogr spatial database layer creation and spit
> > will be working ).
> > Regars
> > Godofredo Contreras
_________________________________________________________________
Help yourself to FREE treats served up daily at the Messenger Café. Stop by today.
http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid=TXT_TAGLM_OctWLtagline
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20071024/9e65367c/attachment.html
