[Qgis-developer] Moving forward with the raster transparency branch
Peter Ersts ersts at amnh.org
Tue Sep 11 10:47:42 EDT 2007
QGIS Devs,
There has been interest in merging the mods in the
raster_transparency_branch into the 0.9.1 release. The main changes
currently are:
1) Revival of basic contrast enhancement
2) Introduction of transparent pixel lists
3) Foundation for basic color ramps.
More information about the raster_transparency_branch can be found here:
http://wiki.qgis.org/qgiswiki/RasterTransparencyBranch
Back in May and June there was a meeting to discuss refactoring of the
monolithic (5K+ lines) QgsRasterLayer class. The last UML design can be
found here:
http://wiki.qgis.org/qgiswiki/RasterRefactorRfc
There still needs to be some discussion regarding the final refactoring
of QgsRasterLayer as there are some great ideas being proposed but
uncertainty regarding the best approach.
In the mean time, I am proposing that contract enhancement and
transparency be the first functionality that is broken out of
QgsRasterLayer, as they are relatively well defined, discrete components
that are well suited for being separate classes. I will undertake this
in the current raster_transparency_branch with the goal of having this
ready for the 0.9.1 release. I propose that classes be named:
QgsRasterTransparencyFilter
QgsRasterContrastEnhancementFilter
I am not sold of the Filter suffix but am still using the June UML as a
bit of a guide. These changes should not affect anything outside of
QgsRasterLayer and should not adversely affect anything class that
inherits QgsRasterLayer.
Please let me know what you think.  Marco, I want to specifically ensure
that these proposed changes will not impact anything you are currently
working on. Again, these changes will be made under the
raster_transparency_branch first, then at a later date merged into the
trunk.
Thanks
-pete
BTW: from the 12 to the 22 I will have limited access to e-mail, so
apologies ahead of time if I am slow to respond .
Peter J. Ersts, Project Specialist
American Museum of Natural History
Center for Biodiversity and Conservation
Central Park West at 79th Street
New York, New York 10024
Tel: (212)-496-3488 or (212)-769-5742
Fax: (212)-313-7295 or (212)-769-5292
Web: http://cbc.amnh.org
Web: http://geospatial.amnh.org
Open Source, Open Mind.
...evolving through community cooperation to change the world bit by bit
