[Qgis-developer] Moving forward with the raster transparency
branch
Marco Hugentobler
marco.hugentobler at karto.baug.ethz.ch
Wed Sep 12 03:35:13 EDT 2007
Hi Peter
I'm glad to see there is an interest in raster layer redesign.
>Marco, I want to specifically ensure
> that these proposed changes will not impact anything you are currently
> working on. Again, these changes will be made under the
> raster_transparency_branch first, then at a later date merged into the
> trunk.
My work in the raster branch is finished for the moment, so no problem.
What about merging the current state of the raster transparency branch to
trunk after release? Like this, all the users (at least those compiling the
newest svn) would benefit from the work that has already been done in the
branch. Raster redesign could then be continued in a branch.
Regards,
Marco
On Tuesday 11 September 2007 16:47:42 Peter Ersts wrote:
> QGIS Devs,
> There has been interest in merging the mods in the
> raster_transparency_branch into the 0.9.1 release. The main changes
> currently are:
> 1) Revival of basic contrast enhancement
> 2) Introduction of transparent pixel lists
> 3) Foundation for basic color ramps.
> More information about the raster_transparency_branch can be found here:
> http://wiki.qgis.org/qgiswiki/RasterTransparencyBranch
> Back in May and June there was a meeting to discuss refactoring of the
> monolithic (5K+ lines) QgsRasterLayer class. The last UML design can be
> found here:
> http://wiki.qgis.org/qgiswiki/RasterRefactorRfc
> There still needs to be some discussion regarding the final refactoring
> of QgsRasterLayer as there are some great ideas being proposed but
> uncertainty regarding the best approach.
> In the mean time, I am proposing that contract enhancement and
> transparency be the first functionality that is broken out of
> QgsRasterLayer, as they are relatively well defined, discrete components
> that are well suited for being separate classes. I will undertake this
> in the current raster_transparency_branch with the goal of having this
> ready for the 0.9.1 release. I propose that classes be named:
> QgsRasterTransparencyFilter
> QgsRasterContrastEnhancementFilter
> I am not sold of the Filter suffix but am still using the June UML as a
> bit of a guide. These changes should not affect anything outside of
> QgsRasterLayer and should not adversely affect anything class that
> inherits QgsRasterLayer.
> Please let me know what you think. Marco, I want to specifically ensure
> trunk.
> Thanks
> -pete
> BTW: from the 12 to the 22 I will have limited access to e-mail, so
> apologies ahead of time if I am slow to respond .
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
