[Qgis-developer] Link issues on mac
John C. Tull
john.tull at wildnevada.org
Thu Apr 3 16:24:30 EDT 2008
Tom,
I tried your patch and got an error. I am on rev 8315 also, so this
might be a problem with how I tried to patch. I put your patch text in
a file 'mac.diff' in the root of my svn directory.
patch -p0 < mac.diff
patching file cmake/FindExpat.cmake
patch: **** malformed patch at line 31: FIND_LIBRARY(EXPAT_LIBRARY
NAMES expat libexpat PATHS
John
On Apr 3, 2008, at 12:39 PM, Tom Elwertowski wrote:
> Hi Tim and William,
> I found the source of the FindGEOS.cmake and FindProj.cmake Mac
> problem. The addition of the NO_DEFAULT_PATH flag to FIND_* made the
> files framework-unfriendly.
> The geos.h header is also missing from the GEOS framework. The file
> is not used by qgis but FindGEOS.cmake references it to locate GEOS.
> I have changed the cmake search reference to geos_c.h which is
> present (and also not used by qgis).
> NO_DEFAULT_PATH was added to force searching of specified paths
> before default paths. /usr/lib paths but not /Library/Frameworks
> were then explicitly added.
> The Cmake documentation recommends calling FIND twice to achieve the
> same effect. First with only nonstandard paths and the
> NO_DEFAULT_PATH flag. Then again with no specified paths to search
> the default locations. When an earlier FIND succeeds, later FINDs
> for the same item do nothing.
> The multiple FIND method avoids the need to list standard paths (and
> perhaps forget about frameworks). It is also compatible with the
> CMAKE_FIND_FRAMEWORK setting which might be LAST, ONLY or NEVER
> rather then the default FIRST. (Hardcoding the all path permutations
> would look awful.)
> Since the default paths were inserted into the middle of the
> nonstandard paths, apparently for mingw and perhaps msvc too, I have
> attached the Mac fix as a patch to be verified and perhaps adjusted
> for those systems before being submitted to svn. Perhaps a third
> FIND is needed if the defaults really need to be in the middle of
> the list.
> Tom
>> When I run cmake, I get the following message:
>> CMake Error: This project requires some variables to be set,
>> and cmake can not find them.
>> Please set the following variables:
>> GEOS_INCLUDE_DIR
>> GEOS_LIBRARY
>> PROJ_INCLUDE_DIR
>> PROJ_LIBRARY
> Index: cmake/FindExpat.cmake
> --- cmake/FindExpat.cmake (revision 8315)
> +++ cmake/FindExpat.cmake (working copy)
> @@ -7,29 +7,26 @@
> # EXPAT_INCLUDE_DIR
> # EXPAT_LIBRARY
> -# Normally there is no need to specify /usr/... paths because
> -# cmake will look there automatically. However the NO_DEFAULT_PATH
> -# prevents this behaviour allowing you to use no standard file
> -# locations in preference over standard ones. Note in this case
> -# you then need to explicitly add /usr and /usr/local prefixes
> -# to the search list. This applies both to FIND_PATH and FIND_LIBRARY
> -FIND_PATH(EXPAT_INCLUDE_DIR expat.h
> +# FIND_PATH and FIND_LIBRARY normally search standard locations
> +# before the specified paths. To search non-standard paths first,
> +# FIND_* is invoked first with specified paths and NO_DEFAULT_PATH
> +# and then again with no specified paths to search the default
> +# locations. When an earlier FIND_* succeeds, subsequent FIND_*s
> +# searching for the same item do nothing.
> +FIND_PATH(EXPAT_INCLUDE_DIR expat.h
> "$ENV{LIB_DIR}/include/"
> "$ENV{LIB_DIR}/include/expat"
> - /Users/tim/dev/universal_libs/include
> - /usr/local/include
> - /usr/include
> c:/msys/local/include
> NO_DEFAULT_PATH
> +FIND_PATH(EXPAT_INCLUDE_DIR expat.h)
> #libexpat needed for msvc version
> FIND_LIBRARY(EXPAT_LIBRARY NAMES expat libexpat PATHS
> "$ENV{LIB_DIR}/lib"
> - /usr/local/lib
> - /usr/lib
> c:/msys/local/lib
> NO_DEFAULT_PATH
> +FIND_LIBRARY(EXPAT_LIBRARY NAMES expat libexpat)
> IF (EXPAT_INCLUDE_DIR AND EXPAT_LIBRARY)
> SET(EXPAT_FOUND TRUE)
> Index: cmake/FindSqlite3.cmake
> --- cmake/FindSqlite3.cmake (revision 8315)
> +++ cmake/FindSqlite3.cmake (working copy)
> @@ -7,29 +7,28 @@
> # SQLITE3_LIBRARY
> -FIND_PATH(SQLITE3_INCLUDE_DIR sqlite3.h
> +FIND_PATH(SQLITE3_INCLUDE_DIR sqlite3.h
> "$ENV{LIB_DIR}/include"
> "$ENV{LIB_DIR}/include/sqlite"
> - /usr/include
> #mingw
> NO_DEFAULT_PATH
> +FIND_PATH(SQLITE3_INCLUDE_DIR sqlite3.h)
> -FIND_LIBRARY(SQLITE3_LIBRARY NAMES sqlite3 PATHS
> +FIND_LIBRARY(SQLITE3_LIBRARY NAMES sqlite3 PATHS
> "$ENV{LIB_DIR}/lib"
> - /usr/local/lib
> - /usr/lib
> + #mingw
> c:/msys/local/lib
> NO_DEFAULT_PATH
> +FIND_LIBRARY(SQLITE3_LIBRARY NAMES sqlite3)
> IF (SQLITE3_INCLUDE_DIR AND SQLITE3_LIBRARY)
> SET(SQLITE3_FOUND TRUE)
> Index: cmake/FindProj.cmake
> --- cmake/FindProj.cmake (revision 8315)
> +++ cmake/FindProj.cmake (working copy)
> @@ -7,29 +7,28 @@
> # PROJ_LIBRARY
> -FIND_PATH(PROJ_INCLUDE_DIR proj_api.h
> +FIND_PATH(PROJ_INCLUDE_DIR proj_api.h
> "$ENV{LIB_DIR}/include/proj"
> - /usr/include
> #mingw
> NO_DEFAULT_PATH
> +FIND_PATH(PROJ_INCLUDE_DIR proj_api.h)
> -FIND_LIBRARY(PROJ_LIBRARY NAMES proj PATHS
> +FIND_LIBRARY(PROJ_LIBRARY NAMES proj PATHS
> "$ENV{LIB_DIR}/lib"
> - /usr/local/lib
> - /usr/lib
> + #mingw
> c:/msys/local/lib
> NO_DEFAULT_PATH
> +FIND_LIBRARY(PROJ_LIBRARY NAMES proj)
> IF (PROJ_INCLUDE_DIR AND PROJ_LIBRARY)
> SET(PROJ_FOUND TRUE)
> Index: cmake/FindGEOS.cmake
> --- cmake/FindGEOS.cmake (revision 8315)
> +++ cmake/FindGEOS.cmake (working copy)
> @@ -7,29 +7,27 @@
> # GEOS_LIBRARY
> -FIND_PATH(GEOS_INCLUDE_DIR geos.h
> +FIND_PATH(GEOS_INCLUDE_DIR geos_c.h
> - /usr/include
> #mingw
> NO_DEFAULT_PATH
> +FIND_PATH(GEOS_INCLUDE_DIR geos_c.h)
> FIND_LIBRARY(GEOS_LIBRARY NAMES geos PATHS
> "$ENV{LIB_DIR}/lib"
> - /usr/local/lib
> - /usr/lib
> #mingw
> c:/msys/local/lib
> NO_DEFAULT_PATH
> +FIND_LIBRARY(GEOS_LIBRARY NAMES geos)
> IF (GEOS_INCLUDE_DIR AND GEOS_LIBRARY)
> SET(GEOS_FOUND TRUE)
> Qgis-developer mailing list
