R: [Qgis-developer] Re: [Qgis-user] EPSG:2180 not recognised, although present in srs.db
Maciej Sieczka tutey at o2.pl
Wed Apr 9 03:34:16 EDT 2008
I built QGIS (latest SVN trunk) against an older PROJ 4.5.0 this time,
and GDAL 1.4.4. Still no good. Below is the relevant debug output when
loading the GeoTIFF. Looks like QGIS recognises the CS properly, but
then fails to find a matching one in srs.sb. Any ideas what is the reason?
Nodoby's yet reproduced my problem. Two users even report the sample
GeoTIFF works OK for them. While it doesn't for me, and I can reproduce
the issue on Debian with QGIS built against PROJ 4.5.0 or 4.6.0 and GDAL
1.4.4 or 1.5.1, as well as in Tisham's lastest build for Windows.
Debug:
/home/shoofi/src/straight/qgis09/src/core/raster/qgsrasterlayer.cpp:
506: (readFile) Raster initial SRS
Debug: /home/shoofi/src/straight/qgis09/src/core/qgsspatialrefsys.cpp:
1104: (debugPrint) ***SpatialRefSystem***
1105: (debugPrint) * Valid : false
1106: (debugPrint) * SrsId : -1234357864
1107: (debugPrint) * Proj4 :
1108: (debugPrint) * Desc. :
254: (createFromWkt) QgsSpatialRefSys::createFromWkt(QString theWkt)
using: PROJCS["ETRS89 / Poland
CS92",GEOGCS["ETRS89",DATUM["European_Terrestrial_Reference_System_1989",SPHEROID["GRS
1980",6378137,298.2572221010042,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6258"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4258"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",19],PARAMETER["scale_factor",0.9993],PARAMETER["false_easting",500000],PARAMETER["false_northing",-5300000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","2180"]]
364: (createFromProj4) QgsSpatialRefSys::createFromProj4 wholetext match
on name failed, trying proj4string match
450: (getRecord) QgsSpatialRefSys::getRecord...running query: select *
from tbl_srs where parameters='+proj=tmerc +lat_0=0 +lon_0=19 +k=0.9993
+x_0=500000 +y_0=-5300000 +ellps=GRS80 +units=m +no_defs'
1078: (openDb) QgsSpatialRefSys::openDb path =
/usr/local/qgis09/share/qgis/resources/srs.db
484: (getRecord) QgsSpatialRefSys::getRecord...trying system qgis.db
1078: (openDb) QgsSpatialRefSys::openDb path = /home/shoofi/.qgis/qgis.db
Warning: QgsSpatialRefSys::getRecord failed :  select * from tbl_srs
where parameters='+proj=tmerc +lat_0=0 +lon_0=19 +k=0.9993 +x_0=500000
527: (getRecord) QgsSpatialRefSys::getRecord retrieved:  select * from
425: (createFromProj4) QgsSpatialRefSys::createFromProj4 globbing search
for srsid from this proj string
753: (findMatchingProj) QgsSpatialRefSys::findMatchingProj...
Warning: QgsSpatialRefSys::findMatchingProj will only work if prj acr
ellipsoid acr and proj4string are set!...
427: (createFromProj4) QgsSpatialRefSys::createFromProj4 globbing search
for srsid returned srsid: 0
293: (isValid) It's an invalid SRS without valid proj4 string
Debug:
511: (readFile)
Debug:
512: (readFile) QgsRasterLayer::readFile --- using wkt
Debug:
513: (readFile)
250: (createFromWkt) QgsSpatialRefSys::createFromWkt -- theWkt is
uninitialised, operation failed
Critical: QgsSpatialRefSys::createFromWkt -- theWkt is uninitialised,
operation failed
Debug:
/home/shoofi/src/straight/qgis09/src/gui/qgsprojectionselector.cpp: 151:
(ogcWmsCrsFilterAsSqlExpression) exiting with '1'.
Projection entries found in srs.db: 2680
SQL for projection list:
select description, srs_id, is_geo, name, parameters from vw_srs where 1
order by name, description
SQL for projection list executed ok...
Size of projection list widget : 20
Fetching user projection list...
Debug:
User projection list sqlselect description, srs_id, is_geo, name,
Finding selected attribute using : select srid from tbl_srs where srs_id
= 2585
Debug:
/home/shoofi/src/straight/qgis09/src/gui/qgsprojectionselector.cpp: 276:
(getCurrentProj4String) mySrsId = 2585
Debug:
/home/shoofi/src/straight/qgis09/src/gui/qgsprojectionselector.cpp: 277:
(getCurrentProj4String) USER_PROJECTION_START_ID = 100000
Debug:
/home/shoofi/src/straight/qgis09/src/gui/qgsprojectionselector.cpp: 301:
(getCurrentProj4String) db = /usr/local/qgis09/share/qgis/resources/srs.db
Debug:
/home/shoofi/src/straight/qgis09/src/gui/qgsprojectionselector.cpp: 320:
(getCurrentProj4String) Selection sql: select parameters from tbl_srs
where srs_id = 2585
Item selected : WGS 84
Item selected full string : +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
Maciek
