R: [Qgis-developer] Re: [Qgis-user] EPSG:2180 not recognised, although present in srs.db
Marco Pasetti marco.pasetti at alice.it
Tue Apr 8 19:06:07 EDT 2008
AFAIK Tisham used PROJ 4.5.0 (from Paul Kelly's tarball) and GDAL 1.4.1;
You could try with my test build of 0.9.2 (recently posted in the list);
it has been built with latest releases for all libraries (that is PROJ 4.6.0
and GDAL 1.5.1)
Marco
-----Messaggio originale-----
Da: qgis-developer-bounces at lists.osgeo.org
[mailto:qgis-developer-bounces at lists.osgeo.org] Per conto di Maciej Sieczka
Inviato: martedì 8 aprile 2008 23.02
A: Goyo
Cc: qgis-user at lists.osgeo.org; qgis-developer at lists.osgeo.org;
tisham at apogee.com.au
Oggetto: [Qgis-developer] Re: [Qgis-user] EPSG:2180 not recognised,although
present in srs.db
Goyo pisze:
> I loaded your file in a new project and the detected projection is:
> ETRS89 / Poland CS92
> QGIS SRID: 181
> PosGIS SRID: 2180
That would be correct. Why it does not work for me I still don't know.
> Using 0.9.2x1 from Tim's Launchpad repository and gdal 1.4.2-3 from
> UbuntuGIS in Ubuntu Gutsy.
As I originaly had the problem with GDAL 1.5.1 I tried with the latest
1.4 (1.4.4) release this time. I built it from source on Debian testing
i686 machine, built the latest QGIS trunk against it, and still QGIS does
not recognize EPSG 2180.
Maybe PROJ could be the culprit then? What PROJ version do you use, Goyo?
Anybody knows what GDAL and PROJ versions are used in latest Tisham's build?
Maciek
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
