[Qgis-developer] Quantum GIS 0.9.2 rev8324 Windows Installer [Test
2]
marco.pasetti at alice.it
Wed Apr 9 11:49:06 EDT 2008
Hi all,
here's an update of Quantum GIS 0.9.2 rev8324 Windows Installer.
First of all some few notes about changes:
1. completed Install registry key entries, as done in previous installers (+ the voice "InstallPath")
2. completed UnInstall registry key entries, as done in previous installers
3. added Windows Geometry key entries
4. added the install option for download and *install* also the Alaska Sample Database
5. renamed the directory where the sample databases are saved: from "GIS Database" to "Sample Data"
6. added the "Uninstall" shortcut, with its own icon
7. added the "Website" shortcut (URL), with its own icon
8. fixed Python bindings install bugs
here you can download the new installer: http://gigamaildownload.rossoalice.alice.it/download/download.aspx?AttachmentID=dc5ef874-487a-40cf-9161-c2fbc31f4715&MessageID=bf824e99-2807-42a1-ae4e-2feb92c30d5d <http://mailstore.rossoalice.alice.it/exchweb/bin/redir.asp?URL=http://gigamaildownload.rossoalice.alice.it/download/download.aspx?AttachmentID=dc5ef874-487a-40cf-9161-c2fbc31f4715%26MessageID=bf824e99-2807-42a1-ae4e-2feb92c30d5d>
this said, I would add some basic instructions for testings, *proposals* and notes about my first tests:
INSTRUCTIONS for testing
1. first of all, uninstall the previous release
2. if you have Python and Qt already installed on your system, try to remove their paths from PATH system variable and then test QGIS [it would be better to uninstall them]
3. test QGIS also with the above paths put in PATH system variable [or reinstall Python and Qt]
4. in this release I added a new GRASS Tool Box (GTB) module, r.category: it repalces r.cats, that has been renamed (to r.category) in GRASS 6.3.0RC*; please, make *massive* testings on it, in order to approve its porting to SVN
TEST results and PROPOSALS
1. many descriptions in GTB modules are badly aligned; actually it's not a bug, but just a minor thing; by the way, it would be good to have all of them correctly aligned; I could make the job in few minutes and then port the XML changes to SVN
2. GTB: v.out.dxf icon is missing
3. GTB: r.patch is missing; actually, since r.patch needs multiple rasters as input, and XML modules cannot handle multiple values in input, it doesn't matter if r.patch is missing; by the way, I think that it would be very important to have it in the GTB; if someone could give me some information about GTB XML programming, I could try to solve the problem
4. help doesn't work at all!
That's all.
Thank you for your collaboration,
Marco Pasetti
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080409/2aff07d2/attachment-0001.html
