[Qgis-developer] Re: EPSG:2180 not recognised, although present in srs.db
Richard Duivenvoorde rdmailings at duif.net
Fri Apr 11 11:14:17 EDT 2008
FYI: after a short chat with FrankW I added to trac the following
request: https://trac.osgeo.org/qgis/ticket/1035
If that works, we hopefully keep in sync with proj and family.
Maciej, did you file your zero-ending scalefactor bug/comment in trac?
Because it would be nice if this could be tackled/discussed at the same
time.... Feel free to add it to the srs.db ticket.
Regards,
Maciej Sieczka wrote:
> Maciej Sieczka pisze:
>> I built QGIS (latest SVN trunk) against an older PROJ 4.5.0 this time,
>> and GDAL 1.4.4. Still no good. Below is the relevant debug output when
>> loading the GeoTIFF. Looks like QGIS recognises the CS properly, but
>> then fails to find a matching one in srs.sb. Any ideas what is the
>> reason?
> I think I know what is going on. Since GDAL 1.4.4 there is a change
> [1],[2] that the scale factor k is treated as numeric instead of string
> variable. This results in a following proj4 string for EPSG 2180 in GDAL
>  > 1.4.2:
> +proj=tmerc +lat_0=0 +lon_0=19 +k=0.9993 +x_0=500000 +y_0=-5300000
> +ellps=GRS80 +units=m +no_defs
> Whereas in QGIS srs.db, and GDAL =< 1.4.2 the same EPSG code is
> represented with a slightly different proj4 string:
> +proj=tmerc +lat_0=0 +lon_0=19 +k=0.999300 +x_0=500000 +y_0=-5300000
> The difference in the number of zeros in k factor is enough for QGIS to
> fail to recognize the SRS, if QGIS runs against GDAL 1.4.4 or later. I
> verified that with the latest QGIS SVN trunk and GDAL 1.4.2, 1.4.4, 1.5.1.
> Note that the problem is not limited to EPSG 2180. As can be seen in [1]
> any SRS that uses k is affected. According to the epsg file shipped with
> PROJ 4.5.0, this gives 1328 out of 6442 SRS definitions incompatible
> between QGIS and GDAL > 1.4.2 [3].
> Quite an issue. Can anything be done about it? Just trim ending zeros of
> all k's in the srs.db? That would break comptibility between QGIS and
> GDAL < 1.4.4. Considering that 1.4.4 was released over 4 months ago
> maybe that would not be a big deal though?
> [1]http://trac.osgeo.org/gdal/changeset/12625
> [2]http://trac.osgeo.org/gdal/ticket/1970
> [3]grep "\+k\=.*0" /usr/local/share/proj/epsg
> Maciek
> Qgis-developer mailing list
