[Qgis-developer] Quantum GIS 0.9.2 rev8336 Windows Test Installer
Richard Duivenvoorde rdmailings at duif.net
Sat Apr 12 10:21:44 EDT 2008
Hi Marco,
looks good, thanks for your 'shrinking'-work! My python plugin is
working :-)
1)
Some plugins are not working because they are missing essential plugin
modules:
- qgisrest needs GeoJSON
- newlayer needs psycopg
- qgis_rgb needs gdal
etc.
Maybe if we include python in the installation, we should also include
these also in the windows package?
2)
There is one 'bug' which I do not know if it is a windows-bug...
I filed it in trac.
But if you have deleted your .qgis (documents and settings) the first
python plugin is successfully downloaded, unzipped etc etc.
But after the message "Python plugin installed. Go to Plugins > Plugin
Manager to enable xxx." you get an error message:
  File "", line 2, in
ImportError: No module named xxx
Apparently the Plugin Manager doesn't have the .qgis/python/plugins in
it's (python_)path? Because after a restart of qgis the plugin is shown
in the Plugin Manager and can load ok.
And after ONE python plugin is succesfully installed, ALL other python
plugins are also being installed ok in one time without restart!
I think this should be fixed before releasing 9.2 This because the new
users will not have a .qgis/python/plugin directory so all will fail to
load their first plugin :-(
Added it in trac as a bug: https://trac.osgeo.org/qgis/ticket/1038
3) https://trac.osgeo.org/qgis/ticket/327 (not able to save map as jpg)
is still there :-(
Regards,
Marco Pasetti wrote:
> Hi all,
> I made another windows pre-release build for testings:
> 1. the help section still doesn't work. I'm quite sure that it's not a
> *package* or *build* problem, but only a source code error. Also Jürgen
> had this problem on his MSVC build. It's strange, because on 0.92rc1
> help section worked fine!
> 2. while in the last 0.92rc1 windows package the python plugins didn't
> work, now I figured out how to let them work in a self-contained
> package. Only the mapserver plugin seems to report errors, but I'm quite
> sure that they don't depend on missing python files in the package, but
> that they are generated by errors in python source code.
> 3. I made a big work on packaging. Instead of *following* the previous
> release *architecture*, I preferred to package the files tracing all the
> system calls, thus including the really needed files only. That resulted
> in a package with approx the same *weight* of the previous ones, even if
> I added more that 13 MB of python files (not previously included, but
> needed to let python plugins work).
> 4. this release is based on rev8336; but changes is still on the way
> (for example, Jürgen Fischer an I are working on some improvements on
> GRASS toolbox).
> 5. the installer still needs some improvements, maybe, but it already
> does its work, and install all the files correctly, registry keys and
> (optional) sample dataset inlcuded. Feel free to report suggestions on it.
> That's all. And, now, the installer:
> http://gigamaildownload.rossoalice.alice.it/download/download.aspx?AttachmentID=29170f44-9626-49aa-849a-f90b3f28496d&MessageID=bafc3210-053e-4a1c-b4d9-e6403396e749
> <http://gigamaildownload.rossoalice.alice.it/download/download.aspx?AttachmentID=29170f44-9626-49aa-849a-f90b3f28496d&MessageID=bafc3210-053e-4a1c-b4d9-e6403396e749>
> Please, test it, and report bugs and/or suggestions.
> Thank you for your attention,
> Marco Pasetti
> Qgis-developer mailing list
