[Qgis-developer] python as plugin
Tim Sutton tim at linfiniti.com
Thu Apr 17 08:38:31 EDT 2008
Hi
I like this idea. If I understand it correctly then the 'master'
python plugin would check at run time if python is present and qgis
python bindings are available and then load itself and any available
python plugins?
Regards
Tim
2008/4/15, Jürgen E. Fischer <jef at norbit.de>:
> Hi there,
>  I've been thinking about turning the python support into a plugin.  If
>  we compile with Python support, we have a static python dependency in
>  the qgis binary.
>  I think that's an issue for packaging.  With python support as plugin,
>  we could split the python plugin into a separate shared library.  If
>  python isn't there, the load of the plugin simply fails (similar to the
>  GRASS plugin).
>  On Debian for instance that would open the possiblity to split off the
>  python depencency to a separate package (currently the qgis executable
>  itself depends on python) and make providing individual packages for
>  different python version easier.
>  On Windows we wouldn't need to package python with qgis. We'd just
>  notify the user that python is available and will appear when python is
>  installed.
>  Maybe we should do the same for GRASS.  Instead of packaging GRASS with
>  QGIS on windows, we'd dynamically depend on the WinGRASS package.
>  This could be done by implementing plugin providers implemented in C++
>  that allow to load, unload and list available and loaded plugins.  The
>  plugin provider would be registered with the plugin registry on load.
>  Initially there would be a builtin plugin provider for C++ plugins and a
>  provider plugin for python plugins.  That plugin would depends on the
>  python library and also provide the python bindings.
>  That way we could also generalize the handling of plugins in QgisApp and
>  the plugin manager and eliminate HAVE_PYTHON there.
>  Comments?
>  Jürgen
>  Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
>  Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
>  Software Engineer         D-26506 Norden               http://www.norbit.de
>  norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>  Rheinstrasse 13, 26506 Norden
>  GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>  _______________________________________________
>  Qgis-developer mailing list
>  Qgis-developer at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
QGIS Project Steering Committee Member - Release  Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
