[Qgis-developer] python as plugin
Tim Sutton
tim at linfiniti.com
Thu Apr 17 11:22:51 EDT 2008
Hi
8<------snip-----------
> This leads me to 2 possibilities:
> - make python support a required part of QGIS and integrate the
> support directly in the core library
> - create a dynamic library with python support - QGIS application or
> libraries will try to load the library at run-time. If found, python
> support will be done by calls to this library, if not found, support
> would be disabled
I prefer option 2. For people creating apps against the c++ libs then
they wont need to include python in their packaging considerations.
Regards
Tim
> I think with time and with the amount of nice plugins made in python
> it will be inevitable to make python support a required part.
> Regards
> Martin
> On Tue, Apr 15, 2008 at 8:11 PM, Jürgen E. Fischer <jef at norbit.de> wrote:
> > Hi there,
> > I've been thinking about turning the python support into a plugin. If
> > we compile with Python support, we have a static python dependency in
> > the qgis binary.
> > I think that's an issue for packaging. With python support as plugin,
> > we could split the python plugin into a separate shared library. If
> > python isn't there, the load of the plugin simply fails (similar to the
> > GRASS plugin).
> > On Debian for instance that would open the possiblity to split off the
> > python depencency to a separate package (currently the qgis executable
> > itself depends on python) and make providing individual packages for
> > different python version easier.
> > On Windows we wouldn't need to package python with qgis. We'd just
> > notify the user that python is available and will appear when python is
> > installed.
> > Maybe we should do the same for GRASS. Instead of packaging GRASS with
> > QGIS on windows, we'd dynamically depend on the WinGRASS package.
> > This could be done by implementing plugin providers implemented in C++
> > that allow to load, unload and list available and loaded plugins. The
> > plugin provider would be registered with the plugin registry on load.
> > Initially there would be a builtin plugin provider for C++ plugins and a
> > provider plugin for python plugins. That plugin would depends on the
> > python library and also provide the python bindings.
> > That way we could also generalize the handling of plugins in QgisApp and
> > the plugin manager and eliminate HAVE_PYTHON there.
> > Comments?
> > Jürgen
> > Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
> > Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> > Software Engineer D-26506 Norden http://www.norbit.de
> > norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> > Rheinstrasse 13, 26506 Norden
> > GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
