[Qgis-developer] Postgres SSL connection on Windows fails
Maciej Sieczka tutey at o2.pl
Thu Apr 17 18:21:44 EDT 2008
Hi
Is there a reason why QGIS on Windows (the latest Tisham's build as well
as the latest Marco's one) fails to connect to Postgres database with
SSL? I never had the problem with QGIS on GNU/Linux.
Here's the error:
Connection to dbase on xxx.xx.xx.xx failed. Either the database is down
or your settings are incorrect.
Check your username and password and try again.
The database said:
FATAL:  no pg_hba.conf entry for host "xx.xx.xx.xx", user "user",
database "dbase", SSL off
The "FATAL" message is not correct. There is an appropriate entry in the
pg_hba.conf on the server. And I can connect from the same IP when I use
a Debian machine.
Maciek
