[Qgis-developer] R: Postgres SSL connection on Windows fails
Marco Pasetti marco.pasetti at alice.it
Thu Apr 17 19:18:18 EDT 2008
Hi Maciej,
If I remember well, I built PGSQL without OpenSSL support, because of build
problems with windows under MinGW. I should work on this to let the OpenSSL
compile under MinGW. Since I'm really too busy now, I guess I'll probably do
the job only for the next releases of both GRASS and QGIS.
Regards,
Marco
-----Messaggio originale-----
Da: Maciej Sieczka [mailto:tutey at o2.pl]
Inviato: venerdì 18 aprile 2008 0.22
A: qgis-developer
Cc: tisham at apogee.com.au; marco.pasetti at alice.it
Oggetto: Postgres SSL connection on Windows fails
Hi
Is there a reason why QGIS on Windows (the latest Tisham's build as well as
the latest Marco's one) fails to connect to Postgres database with SSL? I
never had the problem with QGIS on GNU/Linux.
Here's the error:
Connection to dbase on xxx.xx.xx.xx failed. Either the database is down or
your settings are incorrect.
Check your username and password and try again.
The database said:
FATAL:  no pg_hba.conf entry for host "xx.xx.xx.xx", user "user", database
"dbase", SSL off
The "FATAL" message is not correct. There is an appropriate entry in the
pg_hba.conf on the server. And I can connect from the same IP when I use
a Debian machine.
Maciek
