[Qgis-developer] Re: srs.db epsg's added, shrinking?
Frank Warmerdam
warmerdam at pobox.com
Wed Apr 23 14:50:24 EDT 2008
Maciej Sieczka wrote:
> Hi
> Sorry if I'm a pain, but as nobody replies I don't know what to think
> about the issue and how to proceed with srs.db update. Could someone
> (this probly means Frank who has best insight into SRS stuff of his
> software and software he contributes to) please take a closer look and
> tell me if there are problems to expect due to differences in 'k'
> parameter formatting in PROJ, GDAL, PostGIS and QGIS
> Can I just trimm of the spurious zeros in all k parameters in srs.db or
> would that bring side effects in interaction of the mentioned software
> (propably add MapServer to the list, as QGIS can create MapServer map
> files)?
> Moreover I'm affraid PROJ.4 4.6.0 uses wrong (AFAICT) values for many
> coordinate systems. Compare the PROJ.4's epsg file in version 4.5.0 and
> 4.6.0, and see how parameters differ (in terms of real numbers, not only
> number of extra zeros) in many SRS definitions, eg. EPSG 26794-26798,
> 2180, 2255-2262, 2057, 2000-2007 and more. Looks like some rounding
> errors (?). Eg.:
> 4.5.0:
> <4009> +proj=longlat +a=6378450.047548896 +b=6356826.621488444 +no_defs <>
> 4.6.0:
> <4009> +proj=longlat +a=6378450.047548897 +b=6356826.621488445 +no_defs <>
Maciej,
I believe these problems are due to a change in GDAL/OGR to use CPLAtof()
which gives slightly different results than atof() in some cases.
http://trac.osgeo.org/gdal/ticket/2036
Perhaps you could work with Andrey on this problem and then I could
regenerate things.
BTW, we use a custom CPLAtof() so that coordinate systems with non "C"
locale numbers can be parsed, and so that "C" locale numbers can be
parsed in non "C" locales.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
