[Qgis-developer] Re: srs.db epsg's added, shrinking?
Maciej Sieczka
tutey at o2.pl
Thu Apr 24 03:53:42 EDT 2008
Frank Warmerdam pisze:
> Maciej Sieczka wrote:
>> Moreover I'm affraid PROJ.4 4.6.0 uses wrong (AFAICT) values for many
>> coordinate systems. Compare the PROJ.4's epsg file in version 4.5.0
>> and 4.6.0, and see how parameters differ (in terms of real numbers,
>> not only number of extra zeros) in many SRS definitions, eg. EPSG
>> 26794-26798, 2180, 2255-2262, 2057, 2000-2007 and more. Looks like
>> some rounding errors (?). Eg.:
>> 4.5.0:
>> <4009> +proj=longlat +a=6378450.047548896 +b=6356826.621488444
>> +no_defs <>
>> 4.6.0:
>> <4009> +proj=longlat +a=6378450.047548897 +b=6356826.621488445
>> +no_defs <>
> I believe these problems are due to a change in GDAL/OGR to use CPLAtof()
> which gives slightly different results than atof() in some cases.
> http://trac.osgeo.org/gdal/ticket/2036
> Perhaps you could work with Andrey on this problem and then I could
> regenerate things.
Until this issue is resolved I'll suspend any srs.db manipulations. The
discussion is moved to GDAL dev ML [1].
[1]http://lists.osgeo.org/pipermail/gdal-dev/2008-April/016891.html
Maciek
