[Qgis-developer] Patch to Remove Qt3 Dependencies
Marco Hugentobler
marco.hugentobler at karto.baug.ethz.ch
Tue Apr 29 08:00:45 EDT 2008
Hi Jürgen,
I have similar problems applying your ogrmymerge.diff patch (also with -l
option). Is there an easy workaround or could you provide a tar.gz with the
changed/added files?
Regards,
Marco
Am Montag 28 April 2008 17:58:54 schrieb Jürgen E. Fischer:
> Hi Tim
> On Mon, 28. Apr 2008 at 10:00:47 -0300, Tim Sutton wrote:
> > I also had problems with applying the patch - seems to be diffs of
> > various of the CMakeLists.txt files. I did a bit of hacky workarounds
> > and was able to mostly compile under windows and mac with the
> > exception of some qt3isms remaining in:
> > src/plugins/grass/qgsgrassregion.cpp
> > Though I'm unsure if this is simply a symptom of me not tweaking the
> > patch properly.
> I think this is due to different line endings.
> subversion seems to checkout files with the local line ending and so the
> patch sometime fails when you try to apply diffs made on an other
> platform (windows vs. unix vs. macos). patch -l might help.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
