[Qgis-developer] File Browsing From inside QGIS
Mars Sjoden amagine at telus.net
Wed Aug 13 19:55:23 EDT 2008
Wow! 3-6w would be fantastic and totally liveable!
I'll try your  tricks,  and if they do not work, submit a bug.
Thank you.
On 13-Aug-08, at 4:49 PM, Tom Elwertowski wrote:
> Mars Sjoden wrote:
>> When navigating a root directory on my 24" iMac 3ghz, 4Gb Ram, it
>> stalls out QGIS for close to 2 min. (1.45min exact)
> I have delays of 3 to 6 seconds using non-native dialogs. A native
> dialog is able to access the same folders instantly.
> Qt is caching file dialog data in ~/Library/Preferences/
> com.trolltech.plist. Try deleting this file; perhaps it contains
> corrupted data.
> Also try the following program. I have identical browsing times with
> this code and QGIS. If this example is also slow, you should submit
> a bug to Trolltech.
> #include <QApplication>
> #include <QFileDialog>
> int main(int argc, char *argv[])
> QApplication app(argc, argv);
> QFileDialog dialog;
> return dialog.exec();
> Tom
