[Qgis-developer] printing branch ready for testing
John C. Tull
john.tull at wildnevada.org
Sat Aug 16 14:43:26 EDT 2008
On Aug 16, 2008, at 8:31 AM, Hugentobler Marco wrote:
> Hi qgis devs,
> The printcomposer branch is ready for testing now. The branch is
> available with svn:
> svn co https://svn.osgeo.org/qgis/branches/advanced_printing_branch
> I'm going to compile windows binaries next week so that it is also
> possible to test for non-developers. The plan is to merge the
> printing branch to trunk prior to feature freeze for 1.0 (25. August).
> Regards,
> Marco
Marco,
It built and installed well on OS X 10.5.4 and Qt 4.4.1. The
attachment shows some layout issues. After I add a map, trying to add
another map to the composer window seems to fail. Using the print
function, then sending the print output to OS X's Preview.app to view
the print output caused a crash. Here is some of the output, possibly
relevant:
8/16/08 11:40:33 AM [0x0-0x27a27a].org.qgis.qgis[31589] Debug: /Users/
jctull/sources/qgis/advanced_printing_branch/src/core/
qgscoordinatetransform.cpp: 193: (initialise) Source/Dest SRS equal,
shortcircuit is set.
qgsvectorlayer.cpp: 295: (drawLabels) Starting draw of labels
qgsmaprenderer.cpp: 420: (render) Rendering completed in (seconds):
9.188
8/16/08 11:40:52 AM com.apple.launchd[408]
([0x0-0x27a27a].org.qgis.qgis[31589]) Exited abnormally: Segmentation
fault
I can do some more testing as you progress, but will be in and out of
touch for the next several days.
Regards,
John
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080816/21144f7f/pastedGraphic-0001.png
