[Qgis-developer] no plugin installer present
Otto Dassau otto.dassau at gmx.de
Wed Aug 27 03:28:47 EDT 2008
I have the same (similar) problem building packages on debian lenny and OpenSUSE
SLE_10 and 10.2 using QT 4.4.x. packages.
######## Warnings and Python not being built messages ...
CMake Warning (dev) at CMakeLists.txt:257 (ADD_DEFINITIONS):
Policy CMP0005 is not set: Preprocessor definition values are now escaped
automatically. Run "cmake --help-policy CMP0005" for policy details. Use
the cmake_policy command to set the policy and suppress this warning.
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning (dev) at CMakeLists.txt:258 (ADD_DEFINITIONS):
CMake Warning (dev) at CMakeLists.txt:259 (ADD_DEFINITIONS):
CMake Warning (dev) at src/providers/grass/CMakeLists.txt:1 (ADD_DEFINITIONS):
CMake Warning (dev) at src/plugins/grass/CMakeLists.txt:4 (ADD_DEFINITIONS):
CMake Warning (dev) at src/plugins/grass/CMakeLists.txt:21 (ADD_DEFINITIONS):
QGIS builds but then I don't have python incl. the plugin installer available
with the error message like this on a debian lenny starting qgis
#PyQGIS konnte nicht geladen werden.
#Die Python-Unterstützung wird abgeschaltet.
#Traceback (most recent call last):
#  File "", line 1, in
#ImportError: No module named qgis.core
#Python-Version:
#2.5.2 (r252:60911, Aug 16 2008, 14:40:27)
#[GCC 4.3.1]
#Python-Pfad:
#['/python', '/home/dassau/.qgis//python/plugins', '/python/plugins',
#'/usr/lib/python25.zip', '/usr/lib/python2.5',
#'/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
#'/usr/lib/python2.5/lib-dynload', '/usr/local/lib/python2.5/site-packages',
#'/usr/lib/python2.5/site-packages', '/usr/lib/python2.5/site-packages/Numeric',
#'/usr/lib/python2.5/site-packages/PIL',
#'/usr/lib/python2.5/site-packages/gst-0.10',
#'/var/lib/python-support/python2.5',
#'/usr/lib/python2.5/site-packages/gtk-2.0',
#'/var/lib/python-support/python2.5/gtk-2.0']
at http://lists.osgeo.org/pipermail/qgis-user/2008-August/003289.html
people said they had to downgrade python-qt4 package to version 4.3.3. to make
it work.This would be really bad for me since I am just preparing the opensuse
build server to create all QGIS 1.0 opensuse rpms with a current QT4 (4.4.x)
version.
So my question :): Is my plan possible at all to build QGIS with QT4 (4.4.x).
Is there a solution to fix this or which QT versions work at the moment?
thanks a lot
 Otto
On Wed, 20 Aug 2008 14:28:14 +0200
Maciej Sieczka <tutey at o2.pl> wrote:
> Maciej Sieczka pisze:
> >> In current trunk (r9046) the plugin installer plugin is not present in
> >> the plugins manager menu. What's wrong?
> > After a rebuild from SVN today, I have the Plugin Installer present.
> ... and after another rebuild yesterday it's gone again. Same as the
> Python console. What's up?
> > When is the 0.05.4 from
> > http://bwj.aster.net.pl/qgis/plugins.xml going to be included?
> (Bump.) Feature freeze is near. It could use some testing.
> Maciek
