[Qgis-developer] no plugin installer present
Tim Sutton tim at linfiniti.com
Thu Aug 28 01:25:22 EDT 2008
Hi Otto
I have been building with qt4 on ubuntu for some time.
regards
tim
On 8/27/08, Otto Dassau <otto.dassau at gmx.de> wrote:
> Hi,
> I have the same (similar) problem building packages on debian lenny and
> OpenSUSE
> SLE_10 and 10.2 using QT 4.4.x. packages.
> ######## Warnings and Python not being built messages ...
> CMake Warning (dev) at CMakeLists.txt:257 (ADD_DEFINITIONS):
> Policy CMP0005 is not set: Preprocessor definition values are now escaped
> automatically. Run "cmake --help-policy CMP0005" for policy details. Use
> the cmake_policy command to set the policy and suppress this warning.
> This warning is for project developers. Use -Wno-dev to suppress it.
> CMake Warning (dev) at CMakeLists.txt:258 (ADD_DEFINITIONS):
> CMake Warning (dev) at CMakeLists.txt:259 (ADD_DEFINITIONS):
> CMake Warning (dev) at src/providers/grass/CMakeLists.txt:1
> (ADD_DEFINITIONS):
> CMake Warning (dev) at src/plugins/grass/CMakeLists.txt:4 (ADD_DEFINITIONS):
> CMake Warning (dev) at src/plugins/grass/CMakeLists.txt:21
> (ADD_DEFINITIONS):
> QGIS builds but then I don't have python incl. the plugin installer
> available
> with the error message like this on a debian lenny starting qgis
> #PyQGIS konnte nicht geladen werden.
> #Die Python-Unterstützung wird abgeschaltet.
> #Traceback (most recent call last):
> #  File "", line 1, in
> #ImportError: No module named qgis.core
> #Python-Version:
> #2.5.2 (r252:60911, Aug 16 2008, 14:40:27)
> #[GCC 4.3.1]
> #Python-Pfad:
> #['/python', '/home/dassau/.qgis//python/plugins', '/python/plugins',
> #'/usr/lib/python25.zip', '/usr/lib/python2.5',
> #'/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
> #'/usr/lib/python2.5/lib-dynload', '/usr/local/lib/python2.5/site-packages',
> #'/usr/lib/python2.5/site-packages',
> '/usr/lib/python2.5/site-packages/Numeric',
> #'/usr/lib/python2.5/site-packages/PIL',
> #'/usr/lib/python2.5/site-packages/gst-0.10',
> #'/var/lib/python-support/python2.5',
> #'/usr/lib/python2.5/site-packages/gtk-2.0',
> #'/var/lib/python-support/python2.5/gtk-2.0']
> at http://lists.osgeo.org/pipermail/qgis-user/2008-August/003289.html
> people said they had to downgrade python-qt4 package to version 4.3.3. to
> make
> it work.This would be really bad for me since I am just preparing the
> opensuse
> build server to create all QGIS 1.0 opensuse rpms with a current QT4 (4.4.x)
> version.
> So my question :): Is my plan possible at all to build QGIS with QT4
> (4.4.x).
> Is there a solution to fix this or which QT versions work at the moment?
> thanks a lot
>  Otto
> On Wed, 20 Aug 2008 14:28:14 +0200
> Maciej Sieczka <tutey at o2.pl> wrote:
>> Maciej Sieczka pisze:
>> >> In current trunk (r9046) the plugin installer plugin is not present in
>> >> the plugins manager menu. What's wrong?
>> > After a rebuild from SVN today, I have the Plugin Installer present.
>> ... and after another rebuild yesterday it's gone again. Same as the
>> Python console. What's up?
>> > When is the 0.05.4 from
>> > http://bwj.aster.net.pl/qgis/plugins.xml going to be included?
>> (Bump.) Feature freeze is near. It could use some testing.
>> Maciek
> Qgis-developer mailing list
Sent from my mobile device
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
