[Qgis-developer] no plugin installer present
Otto Dassau
otto.dassau at gmx.de
Thu Aug 28 03:10:39 EDT 2008
Hi Tim,
On Thu, 28 Aug 2008 07:25:22 +0200
"Tim Sutton" <tim at linfiniti.com> wrote:
> Hi Otto
> I have been building with qt4 on ubuntu for some time.
ok, I guess my problems are homemade. If I don't manage to fix it, I will write
again.
thanks a lot
Otto
> regards
> tim
> On 8/27/08, Otto Dassau <otto.dassau at gmx.de> wrote:
> > Hi,
> > I have the same (similar) problem building packages on debian lenny and
> > OpenSUSE
> > SLE_10 and 10.2 using QT 4.4.x. packages.
> > ######## Warnings and Python not being built messages ...
> > CMake Warning (dev) at CMakeLists.txt:257 (ADD_DEFINITIONS):
> > Policy CMP0005 is not set: Preprocessor definition values are now escaped
> > automatically. Run "cmake --help-policy CMP0005" for policy details. Use
> > the cmake_policy command to set the policy and suppress this warning.
> > This warning is for project developers. Use -Wno-dev to suppress it.
> > CMake Warning (dev) at CMakeLists.txt:258 (ADD_DEFINITIONS):
> > CMake Warning (dev) at CMakeLists.txt:259 (ADD_DEFINITIONS):
> > CMake Warning (dev) at src/providers/grass/CMakeLists.txt:1
> > (ADD_DEFINITIONS):
> > CMake Warning (dev) at src/plugins/grass/CMakeLists.txt:4 (ADD_DEFINITIONS):
> > CMake Warning (dev) at src/plugins/grass/CMakeLists.txt:21
> > (ADD_DEFINITIONS):
> > QGIS builds but then I don't have python incl. the plugin installer
> > available
> > with the error message like this on a debian lenny starting qgis
> > #PyQGIS konnte nicht geladen werden.
> > #Die Python-Unterstützung wird abgeschaltet.
> > #Traceback (most recent call last):
> > # File "", line 1, in
> > #ImportError: No module named qgis.core
> > #Python-Version:
> > #2.5.2 (r252:60911, Aug 16 2008, 14:40:27)
> > #[GCC 4.3.1]
> > #Python-Pfad:
> > #['/python', '/home/dassau/.qgis//python/plugins', '/python/plugins',
> > #'/usr/lib/python25.zip', '/usr/lib/python2.5',
> > #'/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
> > #'/usr/lib/python2.5/lib-dynload', '/usr/local/lib/python2.5/site-packages',
> > #'/usr/lib/python2.5/site-packages',
> > '/usr/lib/python2.5/site-packages/Numeric',
> > #'/usr/lib/python2.5/site-packages/PIL',
> > #'/usr/lib/python2.5/site-packages/gst-0.10',
> > #'/var/lib/python-support/python2.5',
> > #'/usr/lib/python2.5/site-packages/gtk-2.0',
> > #'/var/lib/python-support/python2.5/gtk-2.0']
> > at http://lists.osgeo.org/pipermail/qgis-user/2008-August/003289.html
> > people said they had to downgrade python-qt4 package to version 4.3.3. to
> > make
> > it work.This would be really bad for me since I am just preparing the
> > opensuse
> > build server to create all QGIS 1.0 opensuse rpms with a current QT4 (4.4.x)
> > version.
> > So my question :): Is my plan possible at all to build QGIS with QT4
> > (4.4.x).
> > Is there a solution to fix this or which QT versions work at the moment?
> > thanks a lot
> > Otto
> > On Wed, 20 Aug 2008 14:28:14 +0200
> > Maciej Sieczka <tutey at o2.pl> wrote:
> >> Maciej Sieczka pisze:
> >> >> In current trunk (r9046) the plugin installer plugin is not present in
> >> >> the plugins manager menu. What's wrong?
> >> > After a rebuild from SVN today, I have the Plugin Installer present.
> >> ... and after another rebuild yesterday it's gone again. Same as the
> >> Python console. What's up?
> >> > When is the 0.05.4 from
> >> > http://bwj.aster.net.pl/qgis/plugins.xml going to be included?
> >> (Bump.) Feature freeze is near. It could use some testing.
> >> Maciek
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
