[Qgis-developer] PostGIS dialogue usability/annoyance
Jochen Topf
jochen at remote.org
Wed Dec 3 03:50:58 EST 2008
If you tell me how to open a ticket without getting another ID, I would
do it.
I can't open a ticket as anonymous user, I need some kind of ID. I
don't have that ID and I can't track all the IDs for all the programs I
want to contribute bug reports to.
Jochen
On Wed, Dec 03, 2008 at 09:02:59AM +0100, Düster Horst wrote:
> Date: Wed, 3 Dec 2008 09:02:59 +0100
> From: Düster Horst <Horst.Duester at bd.so.ch>
> To: Jochen Topf <jochen at remote.org>, qgis-developer at lists.osgeo.org
> Subject: AW: [Qgis-developer] PostGIS dialogue usability/annoyance
> Jochen
> Please open a ticket for this issue.
> Regards
> Horst
> Dr. Horst Düster
> GIS-Koordinator, Stv. Amtschef
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
> ----- Originalnachricht -----
> Von: Jochen Topf <jochen at remote.org>
> Gesendet: Mit, 3.12.2008 08:53
> An: qgis-developer at lists.osgeo.org
> Betreff: [Qgis-developer] PostGIS dialogue usability/annoyance
> This is with qgis 1.0.0-Kore-preview2:
> * Open "Add PostGIS layer" dialogue
> * Connect to some database
> If you now double click on a table the SQL dialogue opens, you add
> something there and close the dialogue. You table is selected, everything
> is ok.
> But now you decide that you want to change the sql statement, you double
> click the table again, the dialogue opens, you edit it and close it.
> Now your table is not selected any more. You have to find it again and
> select it before you close the "Add PostGIS layer" dialogue.
> So the problem here is that the first click of a double click in the
> "Add PostGIS layer" dialogue changes the select status of a table just
> like a normal click would.
> I think the behaviour should be different: Double click should open the
> SQL dialogue and after closing it the table should *always* be selected.
> Because thats what you want almost all the time. (Why would you bother
> adding an SQL WHERE clause when you don't want to import the table as a
> new layer.)
> also: it is not obvious that you can open the SQL dialogue with a double
> click. I think there should be another way to open the dialogue, the
> double click should only be a shortcut.
> also: can we do something about the default width of the columns in the
> "Add PostGIS layer" dialogue? My table names tend to be wider than would
> fit and "Geometry column" is smaller normally. Do we need the icons and
> the text in the "Type" column? Maybe the columns could widen themselves
> automatically according to the content?
> Jochen
> Jochen Topf jochen at remote.org http://www.remote.org/jochen/ +49-721-388298
> Qgis-developer mailing list
