[Qgis-developer] Bug with raster "memory"
Jürgen E. Fischer
jef at norbit.de
Mon Dec 8 11:13:35 EST 2008
Hi Ghislain,
On Mon, 08. Dec 2008 at 13:58:55 +0100, Ghislain Picard wrote:
> I got seg fault when loading some raster images with the trunk version.
> It's not due to the raster itself because if A.tif causes a seg fault at
> loading, copying A.tif into B.tif and loading B.tif with qgis works
> fine. It seems qgis records something about the filename of the loaded
> raster and that causes the crash.
> I tried to remove ~/.qgis but the problem persists.
Do you have a .qml file for A.tif and not for B.tif? Or a qmldb-File
in your project directory? Try to remove (or rename) them an see if
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
