[Qgis-developer] Bug with raster "memory"
Ghislain Picard
ghislain.picard at lgge.obs.ujf-grenoble.fr
Mon Dec 8 15:56:18 EST 2008
Thank you, this solves the problem.
Do you need the qml file for investigation ?
Ghislain
Jürgen E. Fischer wrote:
> Hi Ghislain,
> On Mon, 08. Dec 2008 at 13:58:55 +0100, Ghislain Picard wrote:
>> I got seg fault when loading some raster images with the trunk version.
>> It's not due to the raster itself because if A.tif causes a seg fault at
>> loading, copying A.tif into B.tif and loading B.tif with qgis works
>> fine. It seems qgis records something about the filename of the loaded
>> raster and that causes the crash.
>> I tried to remove ~/.qgis but the problem persists.
> Do you have a .qml file for A.tif and not for B.tif? Or a qmldb-File
> in your project directory? Try to remove (or rename) them an see if
> Jürgen
Ghislain Picard
Laboratoire de Glaciologie et Géophysique de l'Environnement
54 rue Molière
38400 St Martin d'Hères, FRANCE
tel : +33 476 82 42 42
fax : +33 476 82 42 01
