[Qgis-developer] Python plugin repositories
Borys Jurgiel borys at wolf.most.org.pl
Thu Dec 18 10:12:07 EST 2008
Thursday 18 of December 2008 06:23:01 Gary Sherman napisaƂ(a):
> All,
> The "official" repository is ready for testing. It consists of an
> administrative interface to manage the upload of plugins and the xml
> generator.
Thanks a lot!
> The XML contains the following new tags, which can be ignored or used
> as desired:
> <qgis_minimum_version/> - Minimum version of qgis required by the plugin
This tag should be required.
Also, I see the possibility to upload plugins for the 0.x.  I thought we're
going to leave the old repository for 0.x and use the new ones only for 1.x.
If you prefer to move completely to the new repositories and close the old
one, I can implement it in Installer.
> The administrative interface is at: http://pyqgis.org/admin/official
I can't edit the plugin you've uploaded. I think every admin should be allowed
to edit any plugin, not only those uploaded by himself.
Regards,
B.
