[Qgis-developer] Python plugin repositories
gsherman
sherman at mrcc.com
Thu Dec 18 14:41:50 EST 2008
On Thu, Dec 18, 2008 at 04:12:07PM +0100, Borys Jurgiel wrote:
> Thursday 18 of December 2008 06:23:01 Gary Sherman napisa?(a):
> > All,
> > The "official" repository is ready for testing. It consists of an
> > administrative interface to manage the upload of plugins and the xml
> > generator.
> Thanks a lot!
> > The XML contains the following new tags, which can be ignored or used
> > as desired:
> > <qgis_minimum_version/> - Minimum version of qgis required by the plugin
> This tag should be required.
> Also, I see the possibility to upload plugins for the 0.x. I thought we're
> going to leave the old repository for 0.x and use the new ones only for 1.x.
> If you prefer to move completely to the new repositories and close the old
> one, I can implement it in Installer.
Right - we can leave the "old" repo active. I'll make the changes to the
admin interface.
> > The administrative interface is at: http://pyqgis.org/admin/official
> I can't edit the plugin you've uploaded. I think every admin should be allowed
> to edit any plugin, not only those uploaded by himself.
I'll look at implementing this tonight.
> Regards,
> B.
