[Qgis-developer] Re: themes in the Grass plugin (r9900)
Borys Jurgiel
borys at wolf.most.org.pl
Sun Dec 28 05:28:07 EST 2008
Sunday 28 of December 2008 09:14:57 Tim Sutton napisał(a):
> Hi
> When I tested with your r9862 change below, it didnt pick up my grass
> 'gis' theme icons.
> If we are going to go the non qrc route we will need to change all the
> plugins to install their icons into
> <CMAKE_INSTALL_PREFIX>/share/qgis/themes/<foo theme>
> The qrc approach is kinda nice in that it makes the plugins self
> contained. Its also possible to combine the two approaches - look in the
> qrc file for the theme icon and if its not there look in the file based
> themes dir, and if its not there either fall back to the default icon.
My idea is to combine them too, but with different search odrer:
1. file-based current theme icon (in share/qgis/themes/[ACTIVE]/plugins/)
2. file-based default theme icon (in share/qgis/themes/default/plugins/)
3. qrc-based local plugin icon
QIcon QgsCopyrightLabelPlugin::getThemeIcon( const QString theName )
QString myCurThemePath = QgsApplication::activeThemePath() + "/plugins/" + theName;
QString myDefThemePath = QgsApplication::defaultThemePath() + "/plugins/" + theName;
QString myQrcPath = ":/" + theName;
if ( QFile::exists( myCurThemePath ) )
return QIcon( myCurThemePath );
else if ( QFile::exists( myDefThemePath ) )
return QIcon( myDefThemePath );
else if ( QFile::exists( myQrcPath ) )
return QIcon( myQrcPath );
else
return QIcon();
It should provide the most uniform look and still saves the plugin
independence. You've written:
// Note this code is duplicated from qgisapp.cpp because
// I didnt want to make plugins dependent on qgsapplication (...)
It's dependent on QgsApplication::activeThemePath() and ::defaultThemePath(),
but it's very easy to liberate by commenting them out and leaving
only the last (qrc) path.
So if you agree, I'll aply this unified combined version to all plugins.
