[Qgis-developer] gusty update problem
Tim Sutton
tim at linfiniti.com
Sun Jan 6 08:39:15 EST 2008
Hi
Yes you have multiple copies of qgis installed.
1) Does explicitly running /usr/bin/qgis work correctly?
2) Please show me the result of:
dpkg -l | grep qgis
Regards
Tim
2008/1/6, mccue at acm.caltech.edu <mccue at acm.caltech.edu>:
> An installation problem (leaving behind old version of qgis)
> Version of ubuntu
> \etc\debian_version
> lenny/sid
> Make certain we are uptodate on qgis
> % sudo apt-get install qgis qgis-plugin-grass
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> qgis is already the newest version.
> qgis-plugin-grass is already the newest version.
> 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
> Run qgis
> % qgis
> qgis: error while loading shared libraries: libgdal1.3.2.so.1:
> cannot open shared object file: No such file or directory
> Check out libgdal
> % apt-cache search libgdal
> libgdal-doc - Documentation for the Geospatial Data Abstraction Library
> libgdal1-1.4.0 - Geospatial Data Abstraction Library
> libgdal1-1.4.0-grass - GRASS extension for the Geospatial Data Abstraction Lib
> libgdal1-dev - Geospatial Data Abstraction Library - Development files
> Check out qgis location
> % whereis qgis
> qgis: /usr/bin/qgis /usr/lib/qgis /usr/local/bin/qgis
> /usr/local/lib/qgis /usr/include/qgis /usr/share/qgis
> Likely culprits
> % lws /usr/local/bin/qgis
> -rwxr-xr-x 1 root root 3173399 2007-09-17 14:54 /usr/local/bin/qgis
> % lw /usr/bin/qgis
> -rwxr-xr-x 1 root root 2688160 2007-12-21 05:23 /usr/bin/qgis
> Check $PATH order
> echo $PATH
> /home/mccue/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:\
> /bin:/usr/games:/home/mccue/bin:/usr/software/bin:\
> /home/mccue/projects/mixmod/MIXMOD/BIN
> Test out /usr/bin/qgis
> /usr/bin/qgis --help
> Quantum GIS - 0.9.1-Ganymede 'Ganymede' (unknown), plus more stuff
> Analysis: qgis in /usr/local/bin executed first and is old (9.0)
> version, which doesn't run under gusty but did under feisty, as 1.3.2
> was the version of libgdall used for it. I'm not enough of a linux
> geek to know whether my upgrade to gusty from feisty wasn't done
> correctly, or whether the qgis install is supposed to remove the old
> version. If the latter, it should be fixed. If the former, I should
> know more about linux.
> Ken McCue
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
