[Qgis-developer] [Fwd: Gusty update problem]
mccue at acm.caltech.edu
Mon Jan 7 15:04:59 EST 2008
I answered Tim directly but I think I'm supposed to reply to the list
also.
------------------------------ Original Message ------------------------------
Subject: Re: [Qgis-developer] gusty update problem
Date: Sun, January 6, 2008 9:50 am
To: "Tim Sutton" <tim at linfiniti.com>
> Hi
> Yes you have multiple copies of qgis installed.
> 1) Does explicitly running /usr/bin/qgis work correctly?
Yes
> 2) Please show me the result of:
> dpkg -l | grep qgis
% dpkg -l | grep qgis
rc libqgis0 0.7.4-5ubuntu1
QGIS Geographic Information System - shared
ii libqgis1 0.9.1-2
ii libqgis1-dev 0.9.1-2
QGIS Geographic Information System - develop
ii qgis 0.9.1-2
Geographic Information System (GIS)
ii qgis-plugin-grass 0.9.1-2
Plugin for accessing GRASS data from QGIS
I should note that I thought I had 9.0 as the old version but I really have
7.4, if I'm reading the above correctly.
> Regards
> Tim
> 2008/1/6, mccue at acm.caltech.edu <mccue at acm.caltech.edu>:
>> An installation problem (leaving behind old version of qgis)
>> Version of ubuntu
>> \etc\debian_version
>> lenny/sid
>> Make certain we are uptodate on qgis
>> % sudo apt-get install qgis qgis-plugin-grass
>> Reading package lists... Done
>> Building dependency tree
>> Reading state information... Done
>> qgis is already the newest version.
>> qgis-plugin-grass is already the newest version.
>> 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
>> Run qgis
>> % qgis
>> qgis: error while loading shared libraries: libgdal1.3.2.so.1:
cannot open shared object file: No such file or directory
>> Check out libgdal
>> % apt-cache search libgdal
>> libgdal-doc - Documentation for the Geospatial Data Abstraction Library
libgdal1-1.4.0 - Geospatial Data Abstraction Library
>> libgdal1-1.4.0-grass - GRASS extension for the Geospatial Data Abstraction
>> Lib
>> libgdal1-dev - Geospatial Data Abstraction Library - Development files
>> Check out qgis location
>> % whereis qgis
>> qgis: /usr/bin/qgis /usr/lib/qgis /usr/local/bin/qgis
/usr/local/lib/qgis /usr/include/qgis /usr/share/qgis
>> Likely culprits
>> % lws /usr/local/bin/qgis
>> -rwxr-xr-x 1 root root 3173399 2007-09-17 14:54 /usr/local/bin/qgis % lw
/usr/bin/qgis
>> -rwxr-xr-x 1 root root 2688160 2007-12-21 05:23 /usr/bin/qgis
>> Check $PATH order
>> echo $PATH
>> /home/mccue/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:\
/bin:/usr/games:/home/mccue/bin:/usr/software/bin:\
>> /home/mccue/projects/mixmod/MIXMOD/BIN
>> Test out /usr/bin/qgis
>> /usr/bin/qgis --help
>> Quantum GIS - 0.9.1-Ganymede 'Ganymede' (unknown), plus more stuff
>> Analysis: qgis in /usr/local/bin executed first and is old (9.0)
version, which doesn't run under gusty but did under feisty, as 1.3.2 was the
version of libgdall used for it. I'm not enough of a linux geek to
know whether my upgrade to gusty from feisty wasn't done correctly, or
whether the qgis install is supposed to remove the old version. If the
latter, it should be fixed. If the former, I should know more about linux.
>> Ken McCue
>> Qgis-developer mailing list
>> Qgis-developer at lists.qgis.org
>> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> Tim Sutton
> QGIS Project Steering Committee Member - Release Manager
> Visit http://qgis.org for a great open source GIS
> openModeller Desktop Developer
> Visit http://openModeller.sf.net for a great open source ecological niche
modelling tool
> Home Page: http://tim.linfiniti.com
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
