[Qgis-developer] [Fwd: Gusty update problem]
Tim Sutton
tim at linfiniti.com
Tue Jan 8 07:11:49 EST 2008
Hi
Sorry if I ever replied to your last email - I lost track of where I
was in the conversation thread :-)
Ok so an oooolder deb on your system may explain it because the newer
ones all install to /usr not /usr/local.
Did you ever build yourself from source? Either way you will need to
clear out the qgis files from your /usr/local tree. I think if you do:
sudo rm /usr/local/bin/*qgis*
sudo rm -rf /usr/local/include/qgis
sudo rm /usr/local/lib/*qgis*
sudo rm -rf /usr/local/share/qgis
You should get it all removed. Please note the above commands perform
wildcard and recursive deletes on your system as root. Please check
carefully before you issue them and I dont take any responsibility if
something bad happens.
Regards
Tim
2008/1/7, mccue at acm.caltech.edu <mccue at acm.caltech.edu>:
> I answered Tim directly but I think I'm supposed to reply to the list
> also.
> ------------------------------ Original Message ------------------------------
> Subject: Re: [Qgis-developer] gusty update problem
> From: mccue at euler.acm.caltech.edu
> Date: Sun, January 6, 2008 9:50 am
> To: "Tim Sutton" <tim at linfiniti.com>
> > Hi
> > Yes you have multiple copies of qgis installed.
> > 1) Does explicitly running /usr/bin/qgis work correctly?
> Yes
> > 2) Please show me the result of:
> > dpkg -l | grep qgis
> % dpkg -l | grep qgis
> rc libqgis0 0.7.4-5ubuntu1
> QGIS Geographic Information System - shared
> ii libqgis1 0.9.1-2
> ii libqgis1-dev 0.9.1-2
> QGIS Geographic Information System - develop
> ii qgis 0.9.1-2
> Geographic Information System (GIS)
> ii qgis-plugin-grass 0.9.1-2
> Plugin for accessing GRASS data from QGIS
> I should note that I thought I had 9.0 as the old version but I really have
> 7.4, if I'm reading the above correctly.
> > Regards
> > Tim
> > 2008/1/6, mccue at acm.caltech.edu <mccue at acm.caltech.edu>:
> >> An installation problem (leaving behind old version of qgis)
> >> Version of ubuntu
> >> \etc\debian_version
> >> lenny/sid
> >> Make certain we are uptodate on qgis
> >> % sudo apt-get install qgis qgis-plugin-grass
> >> Reading package lists... Done
> >> Building dependency tree
> >> Reading state information... Done
> >> qgis is already the newest version.
> >> qgis-plugin-grass is already the newest version.
> >> 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
> >> Run qgis
> >> % qgis
> >> qgis: error while loading shared libraries: libgdal1.3.2.so.1:
> cannot open shared object file: No such file or directory
> >> Check out libgdal
> >> % apt-cache search libgdal
> >> libgdal-doc - Documentation for the Geospatial Data Abstraction Library
> libgdal1-1.4.0 - Geospatial Data Abstraction Library
> >> libgdal1-1.4.0-grass - GRASS extension for the Geospatial Data Abstraction
> >> Lib
> >> libgdal1-dev - Geospatial Data Abstraction Library - Development files
> >> Check out qgis location
> >> % whereis qgis
> >> qgis: /usr/bin/qgis /usr/lib/qgis /usr/local/bin/qgis
> /usr/local/lib/qgis /usr/include/qgis /usr/share/qgis
> >> Likely culprits
> >> % lws /usr/local/bin/qgis
> >> -rwxr-xr-x 1 root root 3173399 2007-09-17 14:54 /usr/local/bin/qgis % lw
> /usr/bin/qgis
> >> -rwxr-xr-x 1 root root 2688160 2007-12-21 05:23 /usr/bin/qgis
> >> Check $PATH order
> >> echo $PATH
> >> /home/mccue/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:\
> /bin:/usr/games:/home/mccue/bin:/usr/software/bin:\
> >> /home/mccue/projects/mixmod/MIXMOD/BIN
> >> Test out /usr/bin/qgis
> >> /usr/bin/qgis --help
> >> Quantum GIS - 0.9.1-Ganymede 'Ganymede' (unknown), plus more stuff
> >> Analysis: qgis in /usr/local/bin executed first and is old (9.0)
> version, which doesn't run under gusty but did under feisty, as 1.3.2 was the
> version of libgdall used for it. I'm not enough of a linux geek to
> know whether my upgrade to gusty from feisty wasn't done correctly, or
> whether the qgis install is supposed to remove the old version. If the
> latter, it should be fixed. If the former, I should know more about linux.
> >> Ken McCue
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.qgis.org
> >> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> > Tim Sutton
> > QGIS Project Steering Committee Member - Release Manager
> > Visit http://qgis.org for a great open source GIS
> > openModeller Desktop Developer
> > Visit http://openModeller.sf.net for a great open source ecological niche
> modelling tool
> > Home Page: http://tim.linfiniti.com
> > Skype: timlinux
> > Irc: timlinux on #qgis at freenode.net
Tim Sutton
niche modelling tool
Skype: timlinux
