[Qgis-developer] extensions to postgis dialog
godofredo contreras
frdcn at hotmail.com
Tue Jan 8 14:58:13 EST 2008
Hi Marco:
I was looking into your patch for postgis dialog and I noticed that in qgsdbsourceselectbase.ui
the encoding combobox is missing. It wont be used anymore?
Regards
Godofredo Contreras
> From: marco.hugentobler at karto.baug.ethz.ch
> To: qgis-developer at lists.qgis.org
> Date: Sat, 29 Dec 2007 16:43:16 +0100
> Subject: Re: [Qgis-developer] extensions to postgis dialog
> Hi all,
> Here is the patch that adds a tree view and options for table search to the
> postgis dialog. Please test it and report bugs and/or comments.
> There are two new classes derived from Qt model in this patch. One is the base
> model and the second one a proxy model that adds the capability of filtering
> according to wildcard or regexp.
> cheers,
> Marco
> Am Freitag 14 Dezember 2007 13:44:12 schrieb Marco Hugentobler:
> > Hi Godofredo and Tim,
> > Thanks for your feedback. So I'll make a patch for svn head with the
> > proposed extensions.
> > > Could I suggest using Qt model/view for this - whever list become lone
> > > I think the model / view approach will always be more efficient. It
> > > also has QSortFilterProxModel by which you can easily add sorting and
> > > filtering.
> > This is a good idea. QSortFilterProxModel will certainly help me with
> > filtering.
> > Reading through the Qt documentation, the model/view concept seems to be a
> > very flexible way of accessing and displaying data. In a way, the qgis
> > vector data provider is also a model.
> > > I was going to suggest also that we create src/models and src/views
> > > for any custom models and views we create.
> > As models are always non-gui related and views are dialogs, would it make
> > sense to have src/core/models and src/app/views?
> > >I think is a good idea, but how could we deal with databases that don´t
> > > use schemas
> > >like mysql? maybe in this case we could place all tables into public
> > > schema.
> > Also possible would be to introduce a schema name "" (empty string)
> > or "default". I suppose you just ignore the schema name when accessing
> > mysql databases?
> > Regards,
> > Marco
> > On Thursday 13 December 2007 17:03:20 Tim Sutton wrote:
> > > Hi
> > > filtering.
> > > http://doc.trolltech.com/4.3/qsortfilterproxymodel.html#details
> > > Regards
> > > Tim
> > > 2007/12/13, Hugentobler Marco <marco.hugentobler at karto.baug.ethz.ch>:
> > > > Hi,
> > > > The list of tables in the postgis connection dialog may become quite
> > > > long for users that have a lot of tables and views. I therefore would
> > > > like the following extensions:
> > > > -Convert the table widget to a tree widget. For every schema, there
> > > > would an item that can be expanded/collapsed and contains the
> > > > tables/views of the schema. Like this, there will be much better
> > > > overview in situations with many schemas/tables/views.
> > > > -Add a line edit that takes regular expressions and, if not empty,
> > > > displays only the entries where the table name matches the regular
> > > > expression.
> > > > Are there any objections or suggestions to this?
> > > > Godofredo, does this fit together with the work you are doing in the
> > > > ogr-plugin-branch and shall I code the dialog extensions also into this
> > > > branch?
> > > > Regards,
> > > > Marco
> > > > _______________________________________________
> > > > Qgis-developer mailing list
> > > > Qgis-developer at lists.qgis.org
> > > > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Institute of Cartography
> ETH Zurich
> Technical Advisor QGIS Project Steering Committee
_________________________________________________________________
Get the power of Windows + Web with the new Windows Live.
http://www.windowslive.com?ocid=TXT_TAGHM_Wave2_powerofwindows_012008
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080108/2e338981/attachment.html
