[Qgis-developer] extensions to postgis dialog
godofredo contreras
frdcn at hotmail.com
Tue Jan 8 15:45:15 EST 2008
I will be working with your patch today and tomorrow to adapt it to ogr-branch. Here are some
problems I found when compiling in windows:
CORE_EXPORT macro is missing in qgsdbfilterproxymodel.h and
and in qgsdbtablemodel.h for being able to link in windows.
Regarding to encoding combobox I haven´t used it with ogr but not
sure if it will be needed .
Regards
Godofredo Contreras
> Subject: AW: [Qgis-developer] extensions to postgis dialog
> Date: Tue, 8 Jan 2008 21:18:34 +0100
> From: marco.hugentobler at karto.baug.ethz.ch
> To: frdcn at hotmail.com
> CC: qgis-developer at lists.qgis.org
> Hi Godofredo,
> Afaik the encoding combobox is not used for postgis layers in qgis anymore, only for ogr layers. The postgis provider sets client encoding to unicode:
> (qgspostgresprovider.cpp, l. 260)
> //set client encoding to unicode because QString uses UTF-8 anyway
> QgsDebugMsg("setting client encoding to UNICODE");
> int errcode=PQsetClientEncoding(pd, "UNICODE");
> That's why I removed the gui element. But know that I'm thinking about it, you probably need the encoding combo box for loading database layers with ogr? If yes then I'm gonna add the combo box to the code in the patch.
> Btw did other developers or users look at the patch too? You know, feature freeze on 10th of January, and it would be really cool to include the patch for 0.9.2...
> Best regards,
> Marco
> -----Ursprüngliche Nachricht-----
> Von: godofredo contreras [mailto:frdcn at hotmail.com]
> Gesendet: Di 08.01.2008 20:58
> An: Hugentobler Marco
> Cc: qgis-developer at lists.qgis.org
> Betreff: RE: [Qgis-developer] extensions to postgis dialog
> Hi Marco:
> I was looking into your patch for postgis dialog and I noticed that in qgsdbsourceselectbase.ui
> the encoding combobox is missing. It wont be used anymore?
> Regards
> Godofredo Contreras
> > To: qgis-developer at lists.qgis.org
> > Date: Sat, 29 Dec 2007 16:43:16 +0100
> > Subject: Re: [Qgis-developer] extensions to postgis dialog
> > Hi all,
> > Here is the patch that adds a tree view and options for table search to the
> > postgis dialog. Please test it and report bugs and/or comments.
> > There are two new classes derived from Qt model in this patch. One is the base
> > model and the second one a proxy model that adds the capability of filtering
> > according to wildcard or regexp.
> > cheers,
> > Marco
> > Am Freitag 14 Dezember 2007 13:44:12 schrieb Marco Hugentobler:
> > > Hi Godofredo and Tim,
> > > Thanks for your feedback. So I'll make a patch for svn head with the
> > > proposed extensions.
> > > > Could I suggest using Qt model/view for this - whever list become lone
> > > > I think the model / view approach will always be more efficient. It
> > > > also has QSortFilterProxModel by which you can easily add sorting and
> > > > filtering.
> > > This is a good idea. QSortFilterProxModel will certainly help me with
> > > filtering.
> > > Reading through the Qt documentation, the model/view concept seems to be a
> > > very flexible way of accessing and displaying data. In a way, the qgis
> > > vector data provider is also a model.
> > > > I was going to suggest also that we create src/models and src/views
> > > > for any custom models and views we create.
> > > As models are always non-gui related and views are dialogs, would it make
> > > sense to have src/core/models and src/app/views?
> > > >I think is a good idea, but how could we deal with databases that don´t
> > > > use schemas
> > > >like mysql? maybe in this case we could place all tables into public
> > > > schema.
> > > Also possible would be to introduce a schema name "" (empty string)
> > > or "default". I suppose you just ignore the schema name when accessing
> > > mysql databases?
> > > Regards,
> > > Marco
> > > On Thursday 13 December 2007 17:03:20 Tim Sutton wrote:
> > > > Hi
> > > > filtering.
> > > > http://doc.trolltech.com/4.3/qsortfilterproxymodel.html#details
> > > > Regards
> > > > Tim
> > > > 2007/12/13, Hugentobler Marco <marco.hugentobler at karto.baug.ethz.ch>:
> > > > > Hi,
> > > > > The list of tables in the postgis connection dialog may become quite
> > > > > long for users that have a lot of tables and views. I therefore would
> > > > > like the following extensions:
> > > > > -Convert the table widget to a tree widget. For every schema, there
> > > > > would an item that can be expanded/collapsed and contains the
> > > > > tables/views of the schema. Like this, there will be much better
> > > > > overview in situations with many schemas/tables/views.
> > > > > -Add a line edit that takes regular expressions and, if not empty,
> > > > > displays only the entries where the table name matches the regular
> > > > > expression.
> > > > > Are there any objections or suggestions to this?
> > > > > Godofredo, does this fit together with the work you are doing in the
> > > > > ogr-plugin-branch and shall I code the dialog extensions also into this
> > > > > branch?
> > > > > Regards,
> > > > > Marco
> > > > > _______________________________________________
> > > > > Qgis-developer mailing list
> > > > > Qgis-developer at lists.qgis.org
> > > > > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> > Dr. Marco Hugentobler
> > Institute of Cartography
> > ETH Zurich
> > Technical Advisor QGIS Project Steering Committee
> _________________________________________________________________
> Get the power of Windows + Web with the new Windows Live.
> http://www.windowslive.com?ocid=TXT_TAGHM_Wave2_powerofwindows_012008
Put your friends on the big screen with Windows Vista® + Windows Live™.
http://www.microsoft.com/windows/shop/specialoffers.mspx?ocid=TXT_TAGLM_CPC_MediaCtr_bigscreen_012008
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080108/dd10ee19/attachment.html
