[Qgis-developer] Clipping symbols
Magnus Homann
magnus at homann.se
Tue Jan 8 16:44:20 EST 2008
In the rendering branch I'm trying to fix clipping of hard symbols
(#705). Much of the confusion comes from the fact the pointSize does not
determine a rectangular boundigbox, but instead specifies an area.
So, for a hard marker with pointSize=10, the area should be the same
between circel, rectangle, diamond and triangle, with the circle as the
determining symbol.
The interesting thing happens when you specifiy a diamond fitting into a
10x10 box, and with the same areas as a circle with radius=5. Not so
easy withou clipping!
And then there is the line width... :-)
Can we all agree that instead a symbol with pointSize=10 should render a
circle with radius=5, a rectangel with side=10, a diamond with
*diagonal*=10 and a triangle with base and height=10. They will then all
have different areas.
The numbers above are including line width, so there will be no exact
area scale.
(Hmm, I got a deja vu writing this. Tim, did we discuss this a couple of
years back? Creepy...)
Magnus
