[Qgis-developer] merging of advanced editing branch planned for
9.1.
Marco Hugentobler
marco.hugentobler at karto.baug.ethz.ch
Wed Jan 9 05:37:47 EST 2008
Hi Tim,
+1 for merging the renderer branch. I already used the patch for qml support
and it worked perfectly.
I'm looking forward for all the new features in 0.9.2 :-)
cheers,
Marco
Am Dienstag 08 Januar 2008 21:39:47 schrieb Tim Sutton:
> Hi All
> +1 for digitising branch merge.
> And Magnus and I will be merging the renderer branch (which includes
> qml support and symbol rotation and scaling support) if there are no
> objections.
> I have also written a quick print plugin - the idea is that it uses a
> predefined template (and in the future a selection of predefined
> templates) to quickly produce a pdf of the current map (with legend
> and scale bar etc), Does anyone have any objections to me merging this
> in to trunk? The plugin is not designed to overlap the more flexible
> map composer work of Steven Bell, but rather provide a solution for
> the 'click and print' crowd. Its probably not the most awe inspiring
> example but you can get an idea here:
> http://flickr.com/photos/timlinux/2178029891/
> Regards
> Tim
> 2008/1/8, Hugentobler Marco <marco.hugentobler at karto.baug.ethz.ch>:
> > Hi qgis devs,
> > The 10th January and with it the feature freeze for 0.9.2 is approaching
> > fast. If there are no objections I'm going to merge the advanced editing
> > branch tomorrow (9.1.). @Peter ok for you to merge the raster
> > transparency branch before feature freeze, maybe on 10th of January? If
> > you don't have time those days I may do the merge if you prefer.
> > Best regards,
> > Marco
> > Dr. Marco Hugentobler
> > Institute of Cartography
> > ETH Zurich
> > Technical Advisor QGIS Project Steering Committee
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
ETH Zurich
