[Qgis-developer] [gdal-dev] Open source API to convert raster
to polygons?
Ricardo Scachetti Pereira
ricardo at tdwg.org
Thu Jan 10 06:42:33 EST 2008
Sorry Joaquim,
You are right. I haven't been precise enough.
What I really need is some API or software library (preferably in C
or C++) that I could use to convert ESRI Arc/Info Grids (the binary
kind) to a Shapefile of polygons. If a library isn't available, a
command line utility that I can call from C/C++ would suffice.
I hope this clarify things a bit.
Cheers,
Ricardo
Joaquim Luis wrote:
>> Ricardo Scachetti Pereira kirjoitti:
>>> Hi all,
>>> Does anyone know of any open source geoprocessing APIs that I
>>> can use to convert raster maps into polygons (as a shapefile or SQL
>>> for PostGIS)? Does QGIS do that?
> Hi,
> I am sorry but I have some difficulties in understanding this discussion.
> What is a raster to polygon conversion?
