[Qgis-developer] [gdal-dev] Open source API to convert raster
to polygons?
Barry Rowlingson
b.rowlingson at lancaster.ac.uk
Thu Jan 10 07:30:23 EST 2008
Ricardo Scachetti Pereira wrote:
> What I really need is some API or software library (preferably in C
> or C++) that I could use to convert ESRI Arc/Info Grids (the binary
> kind) to a Shapefile of polygons. If a library isn't available, a
> command line utility that I can call from C/C++ would suffice.
There's some raster-to-vector conversion tools, but I don't know any
that produce shapefiles. However, if the output is in a sensible enough
format then it should be easy to convert from that to shapefile.
Try these:
http://autotrace.sourceforge.net/
http://delineate.sourceforge.net/screenshots.html
and see if they can successfully trace your rasters.
Mostly these tools will smooth out the jagged edges of raster areas -
is this what you want, or do you want your shapefiles to strictly follow
the raster cell boundaries? That's a different problem altogether, and
probably more easy to do...
Barry
