[Qgis-developer] Adding python bindings for quickprint
Christopher Barker
Chris.Barker at noaa.gov
Wed Jan 16 13:28:33 EST 2008
Martin Dobias wrote:
>> the quick print class *should* work something like this:
>> qp = QgsQuickPrint
>> qp.setMapCanvas ( iface.getMapCanvas() )
>> qp.setOutputPdf ("/tmp/test;pdf")
>> qp.setTitle ("QGIS Rocks")
>> qp.print()
> Besides the parentheses missing in the first command as mentioned
> before, there's a problem with the last statement qp.print() because
> "print" is a python keyword. So it's not possible to call it directly
> and you need to use following workaround to execute it:
> getattr(qp, 'print')()
Wouldn't it make more sense to rename it in the bindings? You don't want
an API that ugly!
qp.Print() or printMap, or .....
in fact, you can't create a class with a "print" method in python, but
maybe you can in C -- but it sure seems like a bad idea!
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
