[Qgis-developer] Digitising icons
Christopher Barker
Chris.Barker at noaa.gov
Thu Jan 17 16:54:20 EST 2008
Hugentobler Marco wrote:
>> Lastly, I wondered if the snapping distance in options panel can be
>> specified as a float
> Right. The (detailed) snapping distances in the project properties can be double, but the standard tolerances in the options panel not. I'm plan to change that in the next time.
For that matter, when you're looking at snapping distance for selection
of a vertex, for example, the distance should really be in pixels, not
in whatever the coordinate system your data is in. Is this possible now?
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
