[Qgis-developer] Qgis crashes attempting to load existing
project files (r7992)
Magnus Homann
magnus at homann.se
Fri Jan 18 10:29:05 EST 2008
Carlos Dávila wrote:
>>> Carlos Dávila escribió:
>>>> I have just built qgis from trunk (r7992) and now it crashes if I
>>>> try to open projects saved with 0.9.1, yesterday's trunk and already
>>>> installed. No problem creating and saving new projects, but cannot
>>>> open them.
>>>> Regards
>>>> Carlos
>>> I installed r7994 and problem persisted, but after rebooting it works
>>> OK. I have no idea where the problem came from.
>>> Carlos
>> Did you get an message box warning from opening project files from
>> older revision of QGIS?
> No, I had disabled that option.
Too bad, because the revision information given there is valuable when
reporting bugs in reading old project files. That's why I in the warning
dialog said you should report that information. It also gave a link on
where to report problems, and what should be included.
It makes it much easier fixing these kind of problems.
I suggest you turn it on, at least when there is problems.
Magnus
