[Qgis-developer] R: Building Qgis with MSYS
marco.pasetti at alice.it
Fri Jan 18 11:20:40 EST 2008
Skipped content of type multipart/alternative-------------- next part --------------
CFLAGS="-O2 -s" CXXFLAGS="-O2 -s" LDFLAGS=-s ./configure --without-libtool --prefix=/usr/local --enable-shared --disable-static --with-libz=/usr/local --with-png=/usr/local
make
make install
rm /usr/local/lib/libgdal.a
g++ -s -shared -o ./libgdal.dll -L/usr/local/lib -lz -lpng ./frmts/o/*.o ./gcore/*.o ./port/*.o ./alg/*.o ./ogr/ogrsf_frmts/o/*.o ./ogr/ogrgeometryfactory.o ./ogr/ogrpoint.o ./ogr/ogrcurve.o ./ogr/ogrlinestring.o ./ogr/ogrlinearring.o ./ogr/ogrpolygon.o ./ogr/ogrutils.o ./ogr/ogrgeometry.o ./ogr/ogrgeometrycollection.o ./ogr/ogrmultipolygon.o ./ogr/ogrsurface.o ./ogr/ogrmultipoint.o ./ogr/ogrmultilinestring.o ./ogr/ogr_api.o ./ogr/ogrfeature.o ./ogr/ogrfeaturedefn.o ./ogr/ogrfeaturequery.o ./ogr/ogrfeaturestyle.o ./ogr/ogrfielddefn.o ./ogr/ogrspatialreference.o ./ogr/ogr_srsnode.o ./ogr/ogr_srs_proj4.o ./ogr/ogr_fromepsg.o ./ogr/ogrct.o ./ogr/ogr_opt.o ./ogr/ogr_srs_esri.o ./ogr/ogr_srs_pci.o ./ogr/ogr_srs_usgs.o ./ogr/ogr_srs_dict.o ./ogr/ogr_srs_panorama.o ./ogr/swq.o ./ogr/ogr_srs_validate.o ./ogr/ogr_srs_xml.o ./ogr/ograssemblepolygon.o ./ogr/ogr2gmlgeometry.o ./ogr/gml2ogrgeometry.o
install libgdal.dll /usr/local/lib
cd ogr
g++ -s ogrinfo.o -o ogrinfo.exe -L/usr/local/lib -lpng -lz -lgdal
g++ -s ogr2ogr.o -o ogr2ogr.exe -lgdal -L/usr/local/lib -lpng -lz -lgdal
g++ -s ogrtindex.o -o ogrtindex.exe -lgdal -L/usr/local/lib -lpng -lz -lgdal
install ogrinfo.exe ogr2ogr.exe ogrtindex.exe /usr/local/bin
cd ../apps
g++ -s gdalinfo.o -o gdalinfo.exe -L/usr/local/lib -lpng -lz -lgdal
g++ -s gdal_translate.o -o gdal_translate.exe -L/usr/local/lib -lpng -lz -lgdal
g++ -s gdaladdo.o -o gdaladdo.exe -L/usr/local/lib -lpng -lz -lgdal
g++ -s gdalwarp.o -o gdalwarp.exe -L/usr/local/lib -lpng -lz -lgdal
g++ -s gdal_contour.o -o gdal_contour.exe -L/usr/local/lib -lpng -lz -lgdal
g++ -s gdaltindex.o -o gdaltindex.exe -L/usr/local/lib -lpng -lz -lgdal
g++ -s gdal_rasterize.o -o gdal_rasterize.exe -L/usr/local/lib -lpng -lz -lgdal
install gdalinfo.exe gdal_translate.exe gdaladdo.exe gdalwarp.exe gdal_contour.exe gdaltindex.exe gdal_rasterize.exe /usr/local/bin
(cd port; make)
make[1]: Entering directory `/usr/local/src/gdal-1.4.1/port'
make[1]: Nothing to be done for `default'.
make[1]: Leaving directory `/usr/local/src/gdal-1.4.1/port'
(cd gcore; make)
make[1]: Entering directory `/usr/local/src/gdal-1.4.1/gcore'
make[1]: Leaving directory `/usr/local/src/gdal-1.4.1/gcore'
(cd alg; make)
make[1]: Entering directory `/usr/local/src/gdal-1.4.1/alg'
make[1]: Leaving directory `/usr/local/src/gdal-1.4.1/alg'
(cd frmts; make)
make[1]: Entering directory `/usr/local/src/gdal-1.4.1/frmts'
make -C gxf install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/gxf'
make[2]: Nothing to be done for `install-obj'.
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/gxf'
make -C gtiff install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/gtiff'
(cd libgeotiff; make install-obj)
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/gtiff/libgeotiff'
make[3]: Nothing to be done for `install-obj'.
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/gtiff/libgeotiff'
(cd libtiff; make install-obj)
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/gtiff/libtiff'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/gtiff/libtiff'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/gtiff'
make -C hfa install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/hfa'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/hfa'
make -C aigrid install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/aigrid'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/aigrid'
make -C aaigrid install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/aaigrid'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/aaigrid'
make -C ceos install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/ceos'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/ceos'
make -C ceos2 install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/ceos2'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/ceos2'
make -C iso8211 install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/iso8211'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/iso8211'
make -C xpm install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/xpm'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/xpm'
make -C sdts install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/sdts'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/sdts'
make -C raw install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/raw'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/raw'
make -C dted install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/dted'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/dted'
make -C mem install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/mem'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/mem'
make -C jdem install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/jdem'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/jdem'
make -C envisat install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/envisat'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/envisat'
make -C elas install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/elas'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/elas'
make -C fit install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/fit'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/fit'
make -C vrt install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/vrt'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/vrt'
make -C usgsdem install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/usgsdem'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/usgsdem'
make -C l1b install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/l1b'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/l1b'
make -C nitf install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/nitf'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/nitf'
make -C bmp install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/bmp'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/bmp'
make -C pcidsk install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/pcidsk'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/pcidsk'
make -C airsar install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/airsar'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/airsar'
make -C rs2 install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/rs2'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/rs2'
make -C ilwis install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/ilwis'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/ilwis'
make -C rmf install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/rmf'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/rmf'
make -C rik install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/rik'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/rik'
make -C leveller install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/leveller'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/leveller'
make -C sgi install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/sgi'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/sgi'
make -C idrisi install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/idrisi'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/idrisi'
make -C bsb install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/bsb'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/bsb'
make -C gif install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/gif'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/gif'
make -C jpeg install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/jpeg'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/jpeg'
make -C png install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/png'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/png'
make -C pcraster install-obj
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/frmts/pcraster'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts/pcraster'
make[1]: Leaving directory `/usr/local/src/gdal-1.4.1/frmts'
(cd ogr; make lib )
make[1]: Entering directory `/usr/local/src/gdal-1.4.1/ogr'
(cd ogrsf_frmts; make)
make[2]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts'
make -C generic
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/generic'
make[3]: Nothing to be done for `default'.
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/generic'
make -C shape
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/shape'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/shape'
make -C ntf
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/ntf'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/ntf'
make -C sdts
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/sdts'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/sdts'
make -C tiger
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/tiger'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/tiger'
make -C s57
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/s57'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/s57'
make -C mitab
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/mitab'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/mitab'
make -C dgn
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/dgn'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/dgn'
make -C gml
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/gml'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/gml'
make -C kml
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/kml'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/kml'
make -C avc
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/avc'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/avc'
make -C rec
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/rec'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/rec'
make -C mem
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/mem'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/mem'
make -C vrt
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/vrt'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/vrt'
make -C csv
make[3]: Entering directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/csv'
make[3]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts/csv'
make[2]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr/ogrsf_frmts'
make[1]: Leaving directory `/usr/local/src/gdal-1.4.1/ogr'
make /usr/local/src/gdal-1.4.1/libgdal.a
make[1]: Entering directory `/usr/local/src/gdal-1.4.1'
make[1]: `/usr/local/src/gdal-1.4.1/libgdal.a' is up to date.
make[1]: Leaving directory `/usr/local/src/gdal-1.4.1'
(cd ogr; make apps)
make[1]: Nothing to be done for `apps'.
(cd apps; make)
make[1]: Entering directory `/usr/local/src/gdal-1.4.1/apps'
make[1]: Leaving directory `/usr/local/src/gdal-1.4.1/apps'
/usr/local/src/gdal-1.4.1/install-sh -d /usr/local/lib
/usr/local/src/gdal-1.4.1/install-sh -c /usr/local/src/gdal-1.4.1/libgdal.a /usr/local/lib
/usr/local/src/gdal-1.4.1/install-sh -d /usr/local/bin
/usr/local/src/gdal-1.4.1/install-sh -d /usr/local/share/gdal
/usr/local/src/gdal-1.4.1/install-sh -d /usr/local/include
