[Qgis-developer] R: Building Qgis with MSYS
marco.pasetti at alice.it marco.pasetti at alice.it
Fri Jan 18 11:50:41 EST 2008
Skipped content of type multipart/alternative-------------- next part --------------
Marco at NOTEBOOKMARCO /usr/local/src/gdal-1.4.1
$ configure-gdal.sh
checking build system type... i686-pc-mingw32
checking host system type... i686-pc-mingw32
checking target system type... i686-pc-mingw32
checking for gcc... gcc
checking for C compiler default output file name... a.exe
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables... .exe
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for a sed that does not truncate output... /bin/sed
checking for egrep... grep -E
checking for ld used by gcc... C:/msys/mingw/mingw32/bin/ld.exe
checking if the linker (C:/msys/mingw/mingw32/bin/ld.exe) is GNU ld... yes
checking for C:/msys/mingw/mingw32/bin/ld.exe option to reload object files... -r
checking for BSD-compatible nm... /mingw/bin/nm
checking whether ln -s works... yes
checking how to recognise dependent libraries... file_magic file format pei*-i386(.*architecture: i386)?
checking for dlltool... dlltool
checking for as... as
checking for objdump... objdump
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... no
checking dlfcn.h presence... no
checking for dlfcn.h... no
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking the maximum length of command line arguments... 8192
checking command to parse /mingw/bin/nm output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -DDLL_EXPORT
checking if gcc PIC flag -DDLL_EXPORT works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (C:/msys/mingw/mingw32/bin/ld.exe) supports shared libraries... yes
checking whether -lc should be explicitly linked in... yes
checking dynamic linker characteristics... Win32 ld.exe
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... C:/msys/mingw/mingw32/bin/ld.exe
checking whether the g++ linker (C:/msys/mingw/mingw32/bin/ld.exe) supports shared libraries... yes
checking for g++ option to produce PIC... -DDLL_EXPORT
checking if g++ PIC flag -DDLL_EXPORT works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for dlopen in -ldl... no
checking for nanosleep in -lrt... no
checking for ANSI C header files... (cached) yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for unistd.h... (cached) yes
checking dbmalloc.h usability... no
checking dbmalloc.h presence... no
checking for dbmalloc.h... no
checking for dlfcn.h... (cached) no
checking for stdint.h... (cached) yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking values.h usability... yes
checking values.h presence... yes
checking for values.h... yes
checking float.h usability... yes
checking float.h presence... yes
checking for float.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking direct.h usability... yes
checking direct.h presence... yes
checking for direct.h... yes
checking whether byte ordering is bigendian... no
checking for 64bit integer type... long long
checking for 64bit file io... yes
checking for stat64... no
checking for fopen64... yes
checking for int... yes
checking size of int... 4
checking for long... yes
checking size of long... 4
checking for int8... no
checking for int16... no
checking for int32... no
checking native cpu bit order... lsb2msb
checking for vprintf... yes
checking for _doprnt... no
checking for snprintf... yes
checking for vsnprintf... yes
checking for atoll... yes
checking for copysign... yes
checking for copysignf... yes
checking for strtof... yes
checking for nan... yes
checking for nanf... yes
checking for getcwd... yes
checking whether nan is declared... no
checking whether nanf is declared... no
checking for gmtime_r... no
checking for localtime_r... no
checking for setlocale... yes
checking for local include/lib path... none
configure: checking whether we should include thread/mutex support......
        thread safe support disabled.
checking for deflateInit_ in -lz... no
using internal libz code.
checking for PostgreSQL... no
configure: error: --with-pg argument is a not an executable file.  It should be the path to the pg_config script, often somewhere like /usr/local/pgsql/bin/pg_config.
