[Qgis-developer] Build compile error
volkan kepoglu
vkepoglu at gmail.com
Sun Jan 20 10:06:25 EST 2008
*I am trying to build QGIS from source code in Ubuntu 7.10 Gutsy Gibbon, but
I couldn't. I followed the instructions in the wiki page buildingFromSource.
The following error has occurred. I think it is about GEOS. installed
version of libgeos-dev is 2.2.3-3. *
*after then, I build geos-3.0.0rc4 from source code. this was previous
error. *
In file included from /usr/local/include/geos.h:27,
from /home/vkepoglu/dev/cpp/qgis/src/core/qgsgeometry.h:26,
from /home/vkepoglu/dev/cpp/qgis/src/core/qgslabel.cpp:29:
/usr/local/include/geos/geom.h:145:2: warning: #warning *** FIXME: to be
removed, temporarly set to allow a quick successful build
[ 67%] Building CXX object
src/app/CMakeFiles/qgis.dir/moc_qgspythondialog.o
Linking CXX executable qgis
/home/vkepoglu/dev/cpp/qgis/build/src/core/libqgis_core.so: undefined
reference to `geos::geom::Coordinate::Coordinate(double, double, double)'
reference to `geos::io::WKTReader::~WKTReader()'
reference to `geos::io::WKTReader::WKTReader(geos::geom::GeometryFactory
const*)'
reference to `geos::geom::Coordinate::~Coordinate()'
collect2: ld returned 1 exit status
make[2]: *** [src/app/qgis] Error 1
make[1]: *** [src/app/CMakeFiles/qgis.dir/all] Error 2
make: *** [all] Error 2
*and then I found explanations for this error in the web suggesting to
build GEOS with higher version. The explanation is something like*
Some Notes on Compiling Applications Against GEOS 3.0.0rc4
Submitted by dylan on Tue, 2007-12-11 19:52.
I recently upgraded to GEOS 3.0.0rc4 <http://geos.refractions.net/> in order
to take advantage of its more robust handling of invalid geometries (damn
shapefiles!). However, there are two mini-bugs in this release which need to
be sorted out when compiling against it (or at least for the two application
I was interested in: QGIS <http://www.qgis.org/> and
StarSpan<http://gforge.casil.ucdavis.edu/frs/?group_id=48>).
Note that the first issue presented here has been resolved in GEOS
3.0.0rc5<http://geos.refractions.net/geos-3.0.0rc5.tar.bz2>
1.
Several of the GEOS source files contain little notes about "warning
*** FIXME: to be removed, temporarly set to allow a quick successful build"
which cause compiler warning messages. While this is not a big problem, it
makes some applications which use the compiler flags -Wall and
-Werrorbarf. This is the default mode for the latest versions of QGIS,
and
therefore the "PEDANTIC" flag in its configuration should be set to *
OFF*.
2.
A recent patch to 'source/inlines.cpp' (included in GEOS 3.0.0rc4)
meant to deal with compiler problems on Windows causes problems for real
operating systems. As documented
here<http://lists.qgis.org/pipermail/qgis-developer/2007-February/001597.html>suggests
changing line 30 of 'source/inlines.cpp' from:
#if defined(__MINGW32__) && !defined(DLL_EXPORT)
to
#if !defined(__MINGW32__) || defined(__MINGW32__) && !defined(DLL_EXPORT)
After doing this, re-compile / re-install GEOS 3.0.0rc4 and
applications built against it should not have any problems with functions
not being defined. This has been submitted as ticket
#166<http://trac.osgeo.org/geos/ticket/166>on the GEOS Trac page. "
*so, I build geos-3.0.0. and pedantic option is off in ccmake by default.
However following error is occurred;*
from /home/vkepoglu/dev/cpp/qgis/python/core/qgsgeometry.sip:21:
/usr/local/include/geos/geom.h:145:2: warning: #warning *** DEPRECATED: You
are using deprecated header geom.h. Please, update your sources according to
new layout of GEOS headers and namespaces
*Do you have any idea? Is there anything that I should do something for
GEOS?*
Volkan Kepoglu
PHD Candidate,
Department of GGIT in METU
Ankara, Turkey.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080120/ba86af75/attachment.html
