[Qgis-developer] Build compile error
Martin Dobias
wonder.sk at gmail.com
Sun Jan 20 14:55:04 EST 2008
On Jan 20, 2008 4:06 PM, volkan kepoglu <vkepoglu at gmail.com> wrote:
> I am trying to build QGIS from source code in Ubuntu 7.10 Gutsy Gibbon, but
> I couldn't. I followed the instructions in the wiki page buildingFromSource.
> The following error has occurred. I think it is about GEOS. installed
> version of libgeos-dev is 2.2.3-3.
I use GEOS 2.2.3 from ubuntu 7.10 with no problems.
> so, I build geos-3.0.0. and pedantic option is off in ccmake by default.
> However following error is occurred;
> In file included from /usr/local/include/geos.h:27,
> from /home/vkepoglu/dev/cpp/qgis/src/core/qgsgeometry.h:26,
> from /home/vkepoglu/dev/cpp/qgis/python/core/qgsgeometry.sip:21:
> /usr/local/include/geos/geom.h:145:2: warning: #warning *** DEPRECATED: You
> are using deprecated header geom.h. Please, update your sources according to
> new layout of GEOS headers and namespaces
Actually this is not an error, just a warning...
Martin
