[Qgis-developer] QGIS Building Error
Aaron Racicot
aaronr at z-pulley.com
Mon Jan 28 19:03:58 EST 2008
Does CMake (i.e. ccmake) find your geos install? When you switch to
advanced mode in ccmake can you verify all "geos" related vars have sane
values?
A
Aaron Racicot - GIS Programmer
360.221.2441 - aaronr at z-pulley.com
z - p u l l e y
pobox 1614
langley wa 98260
www.reprojected.com
> -----Original Message-----
> From: qgis-developer-bounces at lists.qgis.org [mailto:qgis-developer-
> bounces at lists.qgis.org] On Behalf Of Marco Pasetti
> Sent: Monday, January 28, 2008 3:58 PM
> To: QGIS Developer Mailing List
> Subject: [Qgis-developer] QGIS Building Error
> Hi,
> I reported erros building qgis (0.9.1). It reports:
> undefined reference to `geos::io::WKTReader::~WKTReader()
> undefined reference to `geos::geom::Coordinate::~Coordinate()
> Attached the whole error list (txt).
> I created my own MSYS enviroment using GEOS 3.0.0 source code; should I
> use
> 2.2.3 instead? In this case, can I only re-build GEOS using 2.2.3 source
> code, or do I need to repeat all the instructions in the wiki after GEOS?
> Thanks,
> Marco
